sporty doesn't want to cooperate - Page 4 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #31 of 35 (permalink) Old 12-01-2012, 07:26 AM
Hit it she goes boom
GotGold's Avatar
Originally Posted by misinlink View Post
Sounds like it could possibly be a bad ignition switch. Unless of course the key was in the on position when you hooked the battery up.
+1
"Our lady of blessed acceleration don't fail me now."--- Elwood Blues
"What does not kill you makes you stronger..... except for bears, bears will kill you."
"Give her full throttle till ya see God... then back off"--- Some guy in a bar.
GotGold is online now
post #32 of 35 (permalink) Old 12-01-2012, 10:20 AM
icy
Padawan
how about the converter? maybe the battery is not being charged up. seems like you keep draining the battery. (I have no mechanical abilities - please don't listen to me) 2012 Harley models had a problem with the converters. when they heated they stopped feeding the battery with power and you ended up draining your battery. they did a recall and replaced them all but I heard stories that resembles yours from folks around.
icy is offline
post #33 of 35 (permalink) Old 12-01-2012, 02:12 PM Thread Starter
So the wire on the bottom there is the one that causes the gauges to jump.
fox_doc8403 is offline
post #34 of 35 (permalink) Old 12-01-2012, 02:46 PM
GotGold's Avatar
Did you have your ignition switch in the "on" position? If you did not have the key in or turned to the on position, you've got a bad ignition switch....
post #35 of 35 (permalink) Old 12-01-2012, 02:57 PM Thread Starter
key was in my pocket the whole time. thank you guys for all the help.
went ahead and cleared the diagnostic codes and replaced the voltage regulator, took her for a spin checked for new codes and had none. thank you again for all the help everyone.
