Help with axle nut - Page 4 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 12-03-2012, 01:53 PM   #31 (permalink)
Thanks for that. One question, looking at the picture, the left side of the wheel, is that spacer or axle I see there?
Redrooster66 is offline   Reply With Quote
Old 12-05-2012, 04:57 AM   #32 (permalink)
I will try that
Old 12-05-2012, 08:25 PM   #33 (permalink)
use a # 4 screwdriver to tap the axle out or a slide hammer.
eagle1 is offline   Reply With Quote
Old 12-06-2012, 07:13 AM   #34 (permalink)
Thanks. ..
Old 12-06-2012, 07:27 AM   #35 (permalink)
SCHMIDTYS's Avatar
If the axle has a countersink in the nut end don't put anything into it like a punch or similar tool and hit with a BFH, the axle end can split.
Old 12-06-2012, 07:32 AM   #36 (permalink)
That's good to know! ... Thanks!
Old 12-06-2012, 10:58 AM   #37 (permalink)
use a slide hammer to pull the axle out if there is a inditation on the end of the axle you can use a #4 screwdriver to push the axle out.
