» Site Navigation |
» » » » Motorcycle Forums
» Our Partners |
12-02-2012, 11:35 AM
#1 (permalink)
Help with axle nut
Hello everyone
I am looking for some help with my nuts! .... Actually, I have changed the front wheel on the bike but I am having trouble getting the threads on the axle nut to catch. It looks like I slightly damaged the first couple of threads on the axle when I hammered it through. I tried using a die and it appears to have corrected the threads as I can no longer see any type of mis-alignment in the thread pattern but I can't get the nut to "catch" on to the threads. Any advice?
12-02-2012, 12:23 PM
#2 (permalink)
You can try a tap for the nut. Should not have to hammer a axle out if you get neutral weight on the wheel with your lift...try a long shank screwdriver to make a T-handle to twist/pull on the axle itself.
12-02-2012, 12:34 PM
#3 (permalink)
Thanks. .. I'm not trying to get the axle out. I have already changed the wheel and I installed the axle. I had to hammer the axle back in. I'm just trying to get the axle nut back on.
12-02-2012, 12:57 PM
#4 (permalink)
Greasy Member
Originally Posted by Redrooster66
Hello everyone
Next time, stick a screw driver in the hole on the right side and twist the axle out. The axle threads don't go to the end. The tip is hollow, from the machining process and cutting the threads. If you hit it hard enough, you mushroomed the end of the axle and the no larger diameter is preventing the axle nut from going on. If that's the case you'll be replace the axle.
Football Season is over....
Praise the Lowered!
11 year A.M.A. member.
4 year PA ABATE member.
12-02-2012, 12:59 PM
#5 (permalink)
DILLIGAF
Hey Red i would try a tap through the nut, does the nut even look like it is screwed up?. before you put the nut on, I have a quick question did you put anti sieze on the axle shaft? this should help not having to hammer the axle out again.
12-02-2012, 01:19 PM
#6 (permalink)
A new axle nut will determine exactly where your problem lies.
12-02-2012, 02:00 PM
#7 (permalink)
It's not the nut threads that are the issue, it's the threads on the axle. ... The axle nut is new. ... I had the axle in place and realized I forgot a spacer so I had to take the axle out. I used a hammer to bang it out but I did so with a piece of wood in between the hammer and the axle. I don't think I damaged the threads when I took the axle out, I think I did it when I hammered the axle back in. I'm hoping I don't have to buy another axle. This axle is brand new. It cost me $70.00!
12-02-2012, 02:23 PM
#8 (permalink)
take the axle to a machinest. he can chamfer the end of the axle on a lave, then the nut will go on correctly as others have suggested use anti-sieze on the axle & on the inside of the spacers . wrap the threads with some tape before installing the axle to prevent damage.
Reason: spelling
12-02-2012, 02:40 PM
#9 (permalink)
I went to take a picture of it and with the lens zoomed in I was able to get a good look at the issue. The end of the axle is pushed in slightly, making contact with the first thread. It looks like I can maybe get a screw driver in between and possibly pry the end of the axle away from the thread. .... Any thoughts from anyone on attempting this?
12-02-2012, 02:45 PM
#10 (permalink)
Can you screw the nut on with the axle out? If so, are your spacers oriented correctly and is the axle fully seated?
| Thread Tools |
| Display Modes |
Linear Mode
