Originally Posted by SailorDoc
tibadoe, you mentioned the engine heat problem is easily fixed. Being new to the forum and HD's in general, what do you suggest to help with this issue? Appreciate your reply. I have recently traded in for an 07 Ultra w/96ci.
SailorDoc
There are a few things you can do to bring help cool down your 96. A oil cooler, synthetic oils, tuner (stage I), and duals. One by itself dosen't help much but together in combination they work pretty good. I did all the above on my 07 and will do the same on my 09 - worked great. If money is tight at least start with the oil cooler and syn oils.
