» Site Navigation |
» » » » Motorcycle Forums
» Links |
10-06-2009, 11:08 PM
#1 (permalink)
Jas.
Passing Lamps fogging over??
Hey, just curious if anyone else is having problems with their passing lamps fogging over on any "09" models? Mine are on my RK and my buddies are on his Ultra. I did call and speak with HD directly and they said that until they get "numerous" complaints about this they won't warrant them!!!! May i add that this is BS!!!  Jas.
10-07-2009, 10:10 AM
#2 (permalink)
CHOPPA RIDN MADNESS
You might not like my answer but I would drill a 1/8th hole in the bottom of them to let em allow condensation out.If they have some already make sure they are not glogged.
Except riding my Sled.
Lifes journey is not to arrive at the grave safely
10-07-2009, 10:46 AM
#3 (permalink)
My Dixie Wrecked
Mine do the same thing..I just assumed it was the 100% humidity down here...In fact the same thing happens on my car..
"A government big enough to give you everything you want, is big enough to take away everything you have"
Thomas Jefferson
John 11:16 Therefore Thomas, who is called Didymuss, said to his fellow disciples, "Let us also go, so that we may die with Him."
Herd Member 50
10-08-2009, 11:48 AM
#4 (permalink)
09 Road King
Yep I noticed it too while I was putting visors on mine.
Jeff
'09 FLHRCI
Herd Member # 00045
10-08-2009, 12:20 PM
#5 (permalink)
On medication
Sounds like a plan, at least until they Man-up on the warranty gig.
10-08-2009, 12:25 PM
#6 (permalink)
I never noticed it on mine. I keep them on all the time, but there's very little humidity out here.
There are very few personal problems that cannot be solved through a suitable application of high explosives. Scott Adams Any intellectually conceived object is always in the past and therefore unreal. Robert Pirsig
10-08-2009, 01:05 PM
#7 (permalink)
09 Road King
It doesn't look like moisture as much as it does smoke. Mine started at the top of the lamp.
btw RDKing09,What number did you call? I will call the same one. Do you have a name of someone to talk to?
Jeff
'09 FLHRCI
Herd Member # 00045
10-08-2009, 05:59 PM
#8 (permalink)
My 09 RK also has the smoke, not moisture look too, and they are Halogen Headlamps.
10-08-2009, 09:32 PM
#9 (permalink)
ready for FOWL play?
I believe it is formed from residual oils inside the housing heating up from the bulbs....but I may be wrong
HERD #00025
10-08-2009, 11:18 PM
#10 (permalink)
Jas.
I thought it was smoke myself until i did a "Save the Plant" ride here in York PA. It rained on the way over and when i parked it they were completely fogged over. I leave mine on all the time too!! I've never blown a bulb but IMO i just don't think they should be smoked or fogged!! Jirvin, thanks for askin!!! heres the customer service # i called (414)343-4056. Unfortunately i don't have a contact name, they will ask for your vin# so u might wanna have that handy. And Badass, knowing my luck i'll drill holes and it'll get worse!!!
| Thread Tools |
| Display Modes |
Linear Mode
