Originally Posted by topbanana3767
i just finished watching an episode of american thunder and they installed monster oval exhaust,fuel pack, and larger intake ? would these be worth it for the money .has anyone done them ?
Monster Ovals are a great exhaust system. The Monsters are one of the few exhaust systems on the market that actually meet the classic criteria of making power without blowing your eardrums out.
It is possible that your local Harley dealer will have a map that he can download to your EFI that can handle these pipes with a Harley Stage 1 intake. Figure the cost of the pipes and installation, then usually around $150 for the remap, then another $150 for the Stage 1 intake, plus labor to install.
That will give you some inexpensive HP without getting to kinky with an add on fuel management system. If you are on the road and have a problem with it, any Harley dealer should have no problem working on it either.
It's not that I'm anti-fuel management module, it's just that I have seen a lot of guys turn a good running machine into a real dog if the FM is not adjusted correctly. If you go with a FM add-on, then your safest bet is to put it on a dyno and let the mechanic tune it correctly.
Pete
