Old 10-16-2009, 10:11 PM   #1 (permalink)
Any gremlins?
Ok, my first post since my intro.
I'm looking to buy an Ultra Classic, hopefully sometime in the near future. My question is.....are there any gremlins to specific year models between 2002 and 2008 that I need to be on the lookout for? i.e. recalls, certain system problems to be aware of, things that, if they haven't already been repaired, will need to be done at some point....other than normal maintenance. I'll be looking more specifically at the 96ci motors and hopefully a 6 speed tranny.
bulldogparts is offline   Reply With Quote
Old 10-16-2009, 10:36 PM   #2 (permalink)
Mentally unstable.
2007 into 2008 96" crank bearing run-out issue. Avoid. Major repair. Then again, HD can check the VIN and see if anything's been repaired/fixed/ignored or not.
HERD meber #10
Old 10-19-2009, 01:31 PM   #3 (permalink)
MY FIREY HOOP
craiger's Avatar
OH Knowledgeble one ,,please explain the symptoms of said "crank bearing run-out".........If you get a minute.. Tanx.Dave.
fuk ya if ya can't take a joke..
HERD # 57
craiger is offline   Reply With Quote
Old 10-28-2009, 07:12 PM   #4 (permalink)
01's to ( I think) 03 had a recall on the circuit breaker failing. Moco changed the original 40 amp to a 50 amp. To me, it didn't solve the problem. The problem was heat weakening the breaker over time.( Yes, the 50 amp did break down on me). I relocated the breaker from just behind the real cylinder , in battery compartment, to inside the right side cover for other electronics. Cool and dry in there. If I were to do it again, I wouldn't cut the wires to the original breaker, I'd destroy that breaker and use it as a junction block or, just solder the eyelets together to extend the wires.
I understand the 08's had a fuel line plastic fitting recall.
I bought my 01, which is like showroom, for less than half of a new one. It's worked out well for me. There's some real good deals on used now.
alto is offline   Reply With Quote
Old 10-28-2009, 09:04 PM   #5 (permalink)
ruby4me's Avatar
Images: 3
I bought my 02 brand new only thing was the recall on breaker other than that I have had no problems with mine.
Herd # 00055
ruby4me is offline   Reply With Quote
Old 10-28-2009, 09:19 PM   #6 (permalink)
when did it start 4u
Jacket4256's Avatar
03 and up have the new style good FI, that a big plus
1988 FLHS with HACK
2004 Sportster
2006 GTO with idle problem
2008 WRX (DD)
The HERD 00046
A great man once said
Jacket4256 is offline   Reply With Quote
vB code is On
