Old 10-26-2009, 05:53 PM   #1 (permalink)
Engine Stalls
I need some thoughts on a problem I am having. I have a 2007 RK. Last week it suddenly started an occasional backfire when decelerating, and after riding for a while then coming to a stop the engine will drop clear out and die if I don't keep it running with the throttle. I can hear it trying to die out as I slow down through the gears. What has me confused is that I didn't think there were any actual adjustments available on the EFI engines, so it must be a mechanical solution.
Thanks -
Chris
2bizzy is offline   Reply With Quote
Old 10-26-2009, 06:53 PM   #2 (permalink)
Old Member
Hawkmann's Avatar
Images: 7
06 and 07 had problems with the Fuel Check Valve Assembly.
Sex is like air. It's not that important unless you aren't getting any
Hawkmann is offline   Reply With Quote
Old 10-26-2009, 08:25 PM   #3 (permalink)
Thank you. I'm new to both HD and fuel injection, have a lot to learn.
Old 10-27-2009, 01:30 AM   #4 (permalink)
senior citizen
SCHMIDTYS's Avatar
Thanks -
Chris
Only 1 mechanical adjustment on the '07 Delphi FI , the base idle screw and that shouldn't be messed with . All other FI adjustments are done with the HD service computer software .
More likely is that you got some bad gas from the pump , a pretty common problem , water in the gas .
Old 10-27-2009, 02:04 AM   #5 (permalink)
Appalachian American
XDixiecratX's Avatar
Hi 2Bizzy , you ll get a lot more talk here if you ll go and say hello in the New to the Community thread at the top of this forum.
THE HERD # 0001
XDixiecratX is online now   Reply With Quote
Old 10-27-2009, 02:05 AM   #6 (permalink)
SNAFU organizer
vlade's Avatar
Is it happening all the time or just ocasionally? Try returning your throttle all the way to low/stop (in nuetral) after you give it a rev and see if it clears up after. Working on a theory that the electronics is losing it place
sometimes in relation to the mechanical throttle
Old 10-27-2009, 07:55 AM   #7 (permalink)
senior citizen
SCHMIDTYS's Avatar
To reset the TPS cycle the ignition on and off 4 times with hands off the throttle .
For electronic throttles only .
Old 10-27-2009, 08:16 AM   #8 (permalink)
Mentally unstable.
Is it me, or are we seeing more and more of this issue?
HERD meber #10
Old 10-27-2009, 09:22 AM   #9 (permalink)
senior citizen
SCHMIDTYS's Avatar
I'm thinking that all those similar symptom posts are because the people aren't taking the time to do a forum search before posting .
vB code is On
