2010 FLHRC Exhaust Questions - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 05-07-2010, 08:00 AM   #1 (permalink)
I just picked up a 2010 FLHRC and have some questions. With the 2010 specs there is a cat in the head pipe and I dont like that. I plan on replacing the entire exhaust system with a Vance and Hines setup, probably Big Shots True Duals. I have done a lot of homework on this and may end up using a Vance and Hines fuel pack also (it seems the most simple and cheapest too!!) I will probably replace the stock intake with a Big Sucker from Arlen Ness. If anyone has any opinions on this it would be great.
Thanks
Kelly and Danielle Long
KellySLong is offline   Reply With Quote
Old 05-07-2010, 11:41 AM   #2 (permalink)
Vance and Hines Pro Pipe 2-1 System, Best Exhaust out there!
Herd #00009
nolafishr is offline   Reply With Quote
Old 05-15-2010, 08:06 AM   #3 (permalink)
If you change the head pipes and remove the CATS, what do you do with the 02 sensors. and if you leave them, wont that effect the running and cause a engine light or something. I dont know, im just kinda comparing to a car
Jeff Dodson is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
