Saddlebag attachment - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 4 (permalink) Old 11-07-2010, 08:29 AM Thread Starter
I took off the left side saddlebag ... went I went to re-attach it, I can get the back clip locked into place but not the front. Is there a clip behind the attachment bracket that I could have bent?
Thanks for your help.
meinbmw is offline
post #2 of 4 (permalink) Old 11-07-2010, 12:05 PM
DJH1960's Avatar
Try to get both of them engaged and locked at the same time. Also, the rear on the left side of my bike was pushed out, I used a pair of channel lock pliers to bend it back strait and after I got it to lock down again it was okay.
Better to be hated for who you are, then loved for someone you are not.
"The Herd" Member number - 00088
DJH1960 is offline
post #3 of 4 (permalink) Old 11-07-2010, 07:18 PM
Sometimes the bottom rubber mount bumpers are not set on the bottom of the bag are not lined up with the tube rail support not allowing the Bail Head Pins to line up with the frame mount clips. Be sure the bag is completely seated and in the right spot front to back.
hardbagger is offline
post #4 of 4 (permalink) Old 11-08-2010, 05:57 AM Thread Starter
Figured it out
The clip was bent inward towards the rear wheel so that the stud could not engage sufficiently. Took a screwdriver and tweaked it back to the original form and all is good.
meinbmw is offline
