Spark Plug Wires - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 4 (permalink) Old 02-18-2011, 02:54 PM Thread Starter
Spark Plug Wires
How do u change the spark plug wires on an 03 road king they go up under the tank .
Leolarry is offline
post #2 of 4 (permalink) Old 02-20-2011, 01:38 PM
If you can't get to them, then you will have to either do a partial tank removal or a full.
BigRock is offline
post #3 of 4 (permalink) Old 02-20-2011, 01:50 PM
Remove the two bolts holding the front of the tank to the frame, as well as the rear bolt on the tank. Put a towel/thick rag under the rear of the tank, and one under the front of the tank to raise it up as much as possible.
Do not force it!!
Raise the tank as much as you can, or just enough to get the wires off the coil.
You will have to cut the factory nylon ties that hold the wires. I suggest replacing them, as if not, the wires can rub the rockerboxes and ruin the new ones.
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #4 of 4 (permalink) Old 02-20-2011, 02:04 PM
SCHMIDTY's Avatar
Did ya bother to buy a factory service manual before ya started to work on your bike ? It's the best investment in your tool box ! Get the manual and start doing some reading dude / fella !
SCHMIDTY is online now
