Radio problems? - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 32 (permalink) Old 04-09-2011, 03:36 PM Thread Starter
IArider's Avatar
Radio problems?
I was riding down the freeway this afternoon and out of the blue the stereo stopped playing. The unit itself stayed on but it was like the speakers were turned off. I turned the unit off for a few minutes and then back on and it done the same thing again. I went through this process several time with the same result and then it stopped working all together. I can change stations, play a cd, turn the volume up or down but there is nothing coming from the speakers.
any ideas?
Thanks for the help!
. I did remove the outer fairing anc can't see anything loose or disconnected. There are like 3 plugs with the headlight wire that go nowhere though. 2 look like they never had but one looks like it could be from something
IArider is offline
post #2 of 32 (permalink) Old 04-09-2011, 04:28 PM
Boooya!!!
streetnoyz's Avatar
if it is the stock HK radio I have seen this before. nothing you did, the radio outputs are just going bad. should check to see if under warranty.
MooooMember 00023
Father giving advice to son: Never do anything once around the house that you don't want to do for the rest of your life.
- Frank Briggs
A man isn't a man until he has to meet a payroll.
- Ivan Shaffer
You're not drunk if you can lie on the floor without holding on.
- Dean Martin
streetnoyz is offline
post #3 of 32 (permalink) Old 04-09-2011, 04:48 PM Thread Starter
IArider's Avatar
The bike is an 07 so I doubt the radio is under warranty. Maybe time to look for an aftermarket if the HK is only good for 3 years
IArider is offline
post #4 of 32 (permalink) Old 04-10-2011, 05:20 AM
SCHMIDTY's Avatar
With the outer fairing off and looking at the left side of the radio , left from the front of the bike . Check the wire harness that runs down the left rear of the radio , the harness has a tendency to wear thru against the radio heat sink .
Also two of those loose wires are the HDI connectors . What's the color of the one you think goes to something ?
SCHMIDTY is online now
post #5 of 32 (permalink) Old 04-10-2011, 07:15 AM
terd # 27
Tink's Avatar
If you cant fix it you might want to send it to Iron cross. 250.00
Harley Davidson-Harman Kardon Advanced Audio Specialists-radio repair-IRON CROSS AUDIO
Tink is offline
post #6 of 32 (permalink) Old 04-10-2011, 07:37 AM Thread Starter
IArider's Avatar
Its a 2 wire plug. I will check wire colors today. I see that cross will fix these not sure if I want to keep it if this is a common problem. I did notice I have a broken fairing mount while I was in there so I need to take care of that too.
IArider is offline
post #7 of 32 (permalink) Old 04-10-2011, 07:46 AM
SCHMIDTY's Avatar
That fairing mount can be fixed if you don't feel like replacing it . I use a small angle bracket bought at the local hdwr. store , drill a couple holes in it and the fairing mount and bolt it together then bolt it back onto the inner fairing . Stronger than the original flimsy factory bracket .
post #8 of 32 (permalink) Old 04-10-2011, 08:40 AM Thread Starter
IArider's Avatar
I will try that. The factory one looks really thin. I may do that to both sides while I am in there
IArider is offline
post #9 of 32 (permalink) Old 04-10-2011, 12:30 PM Thread Starter
IArider's Avatar
the 2 wire plug has one blue wire and one black wire
IArider is offline
post #10 of 32 (permalink) Old 04-10-2011, 12:34 PM
Old Fart
Tcglide's Avatar
Mine did the exact same thing. With 22 days left on the warranty, they had to replace it with a new one. If not still under warranty, you might want to look at an after market like you said.
2009 Street Glide
Guns are responsible for murder like silverware is responsible for obesity!
Charles Cotterman
Rest In Peace Big Brother.
Tcglide is offline
