Has your shift shaft stripped out yet? - Page 3 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 16Likes
post #21 of 30 (permalink) Old 01-10-2017, 07:54 PM
Images: 5
Found three of the four levers loose ,slightly,when doing my 1000mi on my SGS. Removed added loctite tightened securely been good since. I have checked at each service. When I mentioned it to the tech at dealership he said that it was part of their fastener check during service. Good habit to check all bolts ,peace of mind.
tbrince is offline
post #22 of 30 (permalink) Old 01-11-2017, 02:16 PM
silvereagle50's Avatar
I could be wrong, but there are several talking about checking torques and such. I believe the problem that was originally asked about is the shaft that goes into the tranny. Isn't it behind the the primary? And you can't get to it unless you pull everything apart.
Mike Hutchings Broken Bow, Ok.
2016 CVO RGU
FM Stage 1 CVO Heads
Woods 777 Cams
FM Jackpot 2-1 Exhaust
Dynojet Power Vision Tuner
2012 Street Glide - Traded
2012 Fatboy Lo - Traded in
silvereagle50 is online now
post #23 of 30 (permalink) Old 01-11-2017, 06:18 PM
old scoot coot
tommytailspin's Avatar
no, there are the two on the heel toe shifter the front yoke on the front of the linkage shaft. on the rear of the shaft is the yoke on the shifter shaft coming out of the gear box. it's outside the gear box and behind the rear primary case. plenty of room to check torque on the bolt.
tommytailspin is offline
post #24 of 30 (permalink) Old 01-11-2017, 07:29 PM
Lovin' every minute
Silverback's Avatar
Images: 14
^^^This.
Use an Allen key socket with a wiggler (or u-joint) and an extension on your ratchet. Probably best to break it loose by backing off a half turn, then re-torque it down good and tight. If you just try to go tighter to begin with, friction will probably prevent you from breaking tension to tighten it up.
Jimmers likes this.
"There's no sensation to compare with this
Suspended animation, a state of bliss
" --Pink Floyd
** This line seems to come to mind often while I'm riding.
"Men do not quit playing because they grow old. They grow old because they quit playing." --Oliver Wendell Holmes
"And miles to go before I sleep
...and miles to go before I sleep." -- Robert Frost
If you give up drinking, you don't live longer...it just seems longer
Silverback is online now
post #25 of 30 (permalink) Old 01-12-2017, 06:56 PM
Once the levers are nicely tightened, the ball joints at both ends of the shift rod have a tendency to fail starting at about 25,000 miles. Replacing them with heim joints (spherical rod ends, whichever name you prefer) is usually a permanent fix.
btsom is offline
post #26 of 30 (permalink) Old 01-12-2017, 07:03 PM
SoftailBilly's Avatar
Indeed replaced mine, crap ball joints. Touch oil at each joint once a month depending on weather.
SoftailBilly is online now
post #27 of 30 (permalink) Old 01-13-2017, 09:53 AM
chasarms's Avatar
Originally Posted by Silverback View Post
^^^This.
I took mine al the way out and put a drop of thread locker on it before I torqued it.
Breeze3at likes this.
2011 Ultra Classic Electra Glide FLHTCU
SE255 Cams | Jackpot 2/1/2 SPC | Jackpot 4" Dyno Tuned Mufflers | DynoJet PowerVision
chasarms is offline
post #28 of 30 (permalink) Old 01-14-2017, 01:54 PM
Dirty Member
If you strip your shift shaft then you are yanking it too hard. Keep your hands out of your pants.
Sorry I couldn't pass that one up.
tommytailspin and Jimmers like this.
If it aint broke I'll fix it.
09 EGC Black & Silver
107" FM
TW 555 Cams
Stage 2 Heads
Power Vision Tuner
Jackpot Header & Mufflers
Ultra Struck is online now
post #29 of 30 (permalink) Old 01-15-2017, 06:47 AM Thread Starter
rob175's Avatar
Stopped in at my dealer yesterday and they brought up an interesting point.....they told me that HD made that portion of the linkage (the lever that sometimes strips out) out of a slightly "softer" metal so as to make it somewhat "sacrificial". Meaning, that IF an owner has a habit of pounding down on the heel shifter, then rather than doing any damage to the transmission itself that portion of the linkage will take the hit and eventually fail to save the transmission.
Several, at the dealership pointed out that many who use a heel shifter have a tendency to really stomp on it and thus eventually cause the striping of that portion.....while others have a much "lighter" heel and never experience a failure. However, they all suggested that it's probably a good idea to wrench it snug every once in awhile, just as a precaution. They also commented that HD makes the linkage a bit more complex than needed and should consider a re-design somewhere down the road.
2015 Ultra Limited Low
rob175 is online now
post #30 of 30 (permalink) Old 01-16-2017, 06:50 PM
On Probation
HDSickness's Avatar
Took the lame ass heal shifter off first day I got the bike and keep an eye on the tightness when doing a service.
Also never slam the gears.......No problems in over 50k miles.
Breeze3at and Jimmers like this.
Confuse a liberal.....Use facts and logic.
_____________________________________________
2010 Ultra Limited FLHTK
SE Ventilator
SE Super Tuner
Jackpot Stainless Header
Rinehart 4" Muffs
I'll try to be nicer........If you try to be smarter.
HDSickness is offline
