Road King Jiffy Stand Question - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 5Likes
post #1 of 13 (permalink) Old 03-18-2017, 11:31 AM Thread Starter
Aaaaayyyyy
Monzie's Avatar
I have an '09 FLHP (Police Road King) and a question regarding the jiffy stand.
This one has the cut-off so you can't put the bike in gear with the jiffy stand down.
The stand though, seems quite loose. When I make a sharp left turn I can hear it bouncing on the ground.
Will this need a new spring only or is there some other adjustment I will need to do?
Thanks!
_____________
You must never draw until you know how many are against you, or you've satisfied yourself that you can never know, or you've decided it's your day to die.
Monzie is offline
post #2 of 13 (permalink) Old 03-18-2017, 11:48 AM
SCHMIDTY's Avatar
Look at the spring, you'll be able to see if it's stretched or not. Also check the H-D website with your VIN to see if the kickstand recall included your bike.
Side note, anybody that buys a used Harley should register the bike VIN at the H-D website so they'll receive notices for their bike. The dealer's sales guys are supposed to do that but the sales guys are slackers and after they sell ya they forget ya.
SoftailBilly likes this.
SCHMIDTY is online now
post #3 of 13 (permalink) Old 03-18-2017, 12:18 PM
Frozen Member
naknekpete's Avatar
I dont think any of them have an adjuster so its either gotta be the spring or something is bent but Schmidty would know better.
naknekpete is online now
post #4 of 13 (permalink) Old 03-18-2017, 01:05 PM Thread Starter
Aaaaayyyyy
Monzie's Avatar
I'll check for recall info, and for the cost, will try the spring first and see if that fixes it. If not, I'll run it down to my wrench and have him give a look at it. Thanks guys.
_____________
Monzie is offline
post #5 of 13 (permalink) Old 03-18-2017, 01:37 PM
Frozen Member
naknekpete's Avatar
Got a spring hook? A buddy took off with his stand down last year and had to take it off to heat it up and straighten it out. If I remember right he said that spring was a bugger to get back on.
post #6 of 13 (permalink) Old 03-18-2017, 02:01 PM
Silverback's Avatar
Images: 14
Not too bad when it's on a jack. Position the lift arms so they don't interfere with the jiffy stand range of movement. Remove the the nut and lock tab from the top of the stand. That will allow you to rotate the foot of the stand forward toward the front of the bike. If you rotate it all the way around a bit past parallel to the frame rail, it allows you remove and install the spring with no load on it. Then you can use the leverage of the stand to rotate it back into position and reinstall the lock tab and nut on the top.
That stand is extremely strong. Hard to imagine it getting bent--and I think I might be a little concerned about hearing one up to bend it. If you don't really know what you're doing with a torch, you can weaken the work piece.
"There's no sensation to compare with this
Suspended animation, a state of bliss
" --Pink Floyd
** This line seems to come to mind often while I'm riding.
"Men do not quit playing because they grow old. They grow old because they quit playing." --Oliver Wendell Holmes
"And miles to go before I sleep
...and miles to go before I sleep." -- Robert Frost
If you give up drinking, you don't live longer...it just seems longer
Silverback is online now
post #7 of 13 (permalink) Old 03-18-2017, 02:13 PM
candyman1340's Avatar
it's easy.... support and secure the bike upright, remove the bolt (4), washers (8,9) and stop lock tab (22) at the top of the kick stand. Swing the kickstand forward, remove old spring and install the new one(21), swing the kickstand back to the riding position and replace the stop lock and hardware.
It might take 10 minutes to do if you have to look for a wrench.
A one beer job if you do it by yourself , a six pack if you have help
Ronnie's Harley-Davidson's 2009 Harley Davidson FLHR ROAD KING (FB) | FRAME ASSEMBLY W/ JIFFY STAND Parts List
mcnphotog likes this.
candyman1340 is online now
post #8 of 13 (permalink) Old 03-18-2017, 02:16 PM
Frozen Member
naknekpete's Avatar
Thats what I thought too, but he's my mechanic at work and he straightens out a lot of stuff since my drivers can break an anvil. He was confident it was okay though.
Silverback likes this.
post #9 of 13 (permalink) Old 03-20-2017, 02:12 PM Thread Starter
Aaaaayyyyy
Monzie's Avatar
Lifted it with a lift at my buddies on Saturday. The spring was loose enough it was pretty easy getting it off. I really shoulda looked for a how-to on the replacement - I haven't gotten a book for it yet - it was a bear to force the new spring into place, but we managed. No more sketchy business from the jiffy stand.
_____________
Monzie is offline
post #10 of 13 (permalink) Old 03-21-2017, 10:27 AM
Silverback's Avatar
Images: 14
A Road King will make a man out of you.
E4nf3 likes this.
" --Pink Floyd
