Need some guidance on throttle/rpm problem. - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 9Likes
post #1 of 25 (permalink) Old 06-12-2017, 07:28 AM Thread Starter
I started having throttle issues about 2 months ago, on my 2014 Street Glide Special. It has 30,000 miles on it. At first, it was higher than normal RPM at idle, after being fully warmed up. I'd be sitting at a stop light, and the engine would jump to around 1400 RPM when it normally idles around 950-1050. It would do it for about 2-10 seconds and then come back down. I thought maybe it was the ECM just giving it some more fuel for whatever reason. Then, about two weeks ago, I noticed at a stop sign, I had to give it about 50% throttle to get any response in engine rpm. Didn't do it again until yesterday.
It only seems to do it when I pull the clutch in while shifting, or I'm at idle. I could understand the low end of my throttle being a little less sensitive, considering that's where I spend most of my throttle usage at? But I'm guessing the higher RPM could possibly be the same problem. Maybe consider remapping the ECM? Or do you guys think it's a TPS issue? I REALLY don't want to take my wiring out, considering how much of a pain it was to put in last year.
guitarguy774 is offline
post #2 of 25 (permalink) Old 06-12-2017, 08:54 AM
Wayward Son
Thunder~Struck's Avatar
Real glad you know what year and model you are talking about.
We sure don`t.
JLR likes this.
People are why I love my Dog and my Harley.
___________________________________
You want blood? You got it!
G.F.T.D.
You`ve been, Thunder~Struck !
ATW TWF/FTW
You can have your funky world. See ya round.
I.L.M.O. ROLO
04/03/14-07/27/16
Thunder~Struck is offline
post #3 of 25 (permalink) Old 06-12-2017, 09:07 AM Thread Starter
We sure don`t.
Fixed it!
Thunder~Struck likes this.
post #4 of 25 (permalink) Old 06-12-2017, 09:10 AM
I have no idea on the issue, but it certainly makes it obvious I don't ride enough due to a variety of factors... I have 3-4K on my 2014.
", on my 2014 Street Glide Special. It has 30,000 miles on it. "
rbviolin is online now
post #5 of 25 (permalink) Old 06-12-2017, 09:41 AM
Frozen Member
naknekpete's Avatar
Just guessing here but I would think the little bump in idle is probably due to the ECM and wouldnt concern me much unless it happened a lot or got worse, but the 50% responsiveness thing seems like its probably TPS related and would worry me more.
naknekpete is online now
post #6 of 25 (permalink) Old 06-12-2017, 01:38 PM
On the loose
67Duce's Avatar
Do you have a tuner on it ? Stage one or any other mods ?
2001 Deuce , traded.
2014 Street Glide with stuff
67Duce is online now
post #7 of 25 (permalink) Old 06-12-2017, 03:11 PM
Breeze3at's Avatar
Sounds like a Throttle By Wire module or a bad connection.
I'm a no hyphen (-) American.
Pete / Breeze .380
Breeze3at is online now
post #8 of 25 (permalink) Old 06-12-2017, 05:10 PM
chasarms's Avatar
TBW issue would likely throw a DTC. Did you check for active codes?
Often, high idle once the engine is warm but not when cold is related a temperature sensor failing, but I am unsure if that explains everything.
In any case, I would expect the ECM to log a diagnostic code.
2011 Ultra Classic Electra Glide FLHTCU
SE255 Cams | Jackpot 2/1/2 SPC | Jackpot 4" Dyno Tuned Mufflers | DynoJet PowerVision
chasarms is offline
post #9 of 25 (permalink) Old 06-12-2017, 05:18 PM
SCHMIDTY's Avatar
Originally Posted by 67Duce;6287177[B
]Do you have a tuner on it ? Stage one or any other mods [/B]?
This ^^^ ?
SCHMIDTY is online now
post #10 of 25 (permalink) Old 06-12-2017, 07:09 PM
I would jump on the IAC (Idle Air Control) as being gummed up. Clean it up real good.
slingshot383 likes this.
Regards,
John
Everything is JMHO. Accuracy is not assured.
Originally Posted by Mark Twain
The more I know about people the better I like my dog. -
2007 VRSCX 0461 / 1400
2003 VRSCA Gone but not forgotten.
2002 Road King Classic
Rustyg is online now
