113 SE Dyno Results - Page 3 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #21 of 29 (permalink) Old 01-25-2012, 02:25 PM
redman24's Avatar
Images: 15
Originally Posted by Robbo1976 View Post
I think you're right about the cat not being gutted. The mufflers still have baffles in them. I think over the summer I will have to ditch the whole system and go aftermarket. Anyone have suggestions for a good exhaust system for the SG?
I really like my V&H Power Duals, but your getting better than me the way you are. My seat of the pants pull is great. I am still thinking of cams. I don't see much on this site about the S&S Cams, but they sure worked great on my custom.
Red
redman24 is online now
post #22 of 29 (permalink) Old 01-25-2012, 08:40 PM
murf's Avatar
Originally Posted by Chief Illiniwek View Post
Robbo, Ben, explain yourselves. We too want triumphant ponies. I've got SE a/c, slip ons, and Power Commander V with two rounds of dyno time and I'm at 71 hp and upper 80's tq. Fuel? What air cleaner did you upgrade to? Etc.?
I'm hungry. Hook us up.
I'm hungry too for those figures from a 103, especially the torque. I put on a set of the Supertrapp 4" Stout slip-ons, SE Ventilator air cleaner, and the tech did the factory Stage 1 download. The best dyno run was 77.45 HP and 93.97 lbs/ft. of torque. Air temp was 77.5 deg F. and humidity was 9% during the dyno runs.
Robbo1976's figures of just under 84 hp and 104 lbs/ft of torque are impressive for a stage 1 103" motor.
murf is offline
post #23 of 29 (permalink) Old 01-26-2012, 07:56 AM
Millwright
petew's Avatar
Stage 2 gets me 92 hp from my 103. Cams were needed just to get to those numbers.
103" w/Race Kit,Stage IV 117HP 111TQ
SE 259E Cams
SE Heavy Breather AC (Scott's modified)
SE Race Tuner
V&H Power Duals & Hi Outputs
SE CNC Heads 10.62/1 w/SE 58mm TB
John Scott port matching
Renegade Racine wheels. 21x3.5/ 17x6.25
http://www.harley-davidsonforums.com...845-petew.html
petew is offline
post #24 of 29 (permalink) Old 01-26-2012, 09:54 AM
redman24's Avatar
Images: 15
That may be exactly what I need.
Red
post #25 of 29 (permalink) Old 01-26-2012, 10:56 AM
DevilDogBagger's Avatar
Images: 13
I have a 96 stage 1 and it dyno'd 88HP and 100TQ.
2008 UltraClassic ( Vivid Black ) SE Stage 1 AC - SEST - Rinehart True duals - Dunlop Elite 3's
88 HP - 100 TQ - 13:1 AFR
_________________________________
Herd member # 00075
" If a hammer won't fix it you got an electrical problem "
DevilDogBagger is offline
post #26 of 29 (permalink) Old 01-26-2012, 01:33 PM
redman24's Avatar
Images: 15
Wow, that is real great. I wouldn't change a thing.
Don't want to steal the thread, but there are alot of engine upgrade threads. This 113 sounds like a beast. We gotta see some video.
My dad always told more power is always good.
The real number I need is enough power to get out of a really tight situation. With the pure stage 1, I am close, but there are times when I need to get it with me and my wife and it will push past 5k rpm. Houston traffic is a beast and will eat you if your not careful. Power, ABS brakes, training, experience, quick thinking and a very nimble bike are required for survival.
More than the necessaries to survive are for me cause I like it.
Red
post #27 of 29 (permalink) Old 01-26-2012, 11:30 PM
Seor Member
Chief Illiniwek's Avatar
Images: 38
Couldn't agree more, murf AND red. Power saves lives and is a metric butt-ton of fun too.
2011 Road King Classic, Cary Faas Racing mufflers on V&H Dresser Duals, Arlen Ness Big Sucker Stage II Air Cleaner, Power Commander V
Chief Illiniwek is online now
post #28 of 29 (permalink) Old 01-27-2012, 10:20 AM
88hp from a 96" with no cams?
2007 FLHRC
106" S&S
Arlen Ness Big Sucka
Andrews 37 Cams
Full Head Work
Rhinehart True Duals
10:1 comp
HP 116 Tq 120
SOLD!
rwelch0121 is offline
post #29 of 29 (permalink) Old 01-29-2012, 06:31 AM
OneLugLarry's Avatar
Images: 3
I have been told by quite a few old timers and motor builders that a lot of people can put false info like different air temp , humidity, etc.etc into there computer on the dyno to bump up the dyno numbers. I was doubtful but one fellow showed me three dyno sheets for the same bike. He had a cutomer run there bike on his dyno then the guy went to a rally 25 miles away and ran it on some traveling dyno there and it showed 13 hp more. the guy called him up pissed off so he said to bring it back and he wanted to rerun it. They ran it it it was within a horse of the original dyno sheet. The bike owner himself said that they only strapped the bike down and did no mods at the rally . you have to compare your before and after dyno runs useing the same dyno to see your gain. All that being said dyno runs realy dont mean sh7t . Drag strips and smiles are what it is about. My 2000 ultra with 95", cams, PC,big sucker, V@H mufflers only reads 78hp but I run with guys (and beat) who are talking bigger numbers on different dynos.
OneLugLarry is offline
