How to remove inner fairing Electra? - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 13 (permalink) Old 02-19-2012, 04:32 PM Thread Starter
Admiral Achbar's Avatar
Hey, been searching all day, trying to find a good how-to tutorial for removing inner fairing for Electra Glide..( having mine color matched to outer) any suggestions? Dont want to go at it blind if I don't have to.... anyone have this done, or have done it themselves? Pics?
Thanks in advance...
Admiral Achbar is offline
post #2 of 13 (permalink) Old 02-19-2012, 05:10 PM
Smokin Ogre
Ogre3239's Avatar
Do a search on youtube. I have found many helpful videos there.
2012 Ultra Classic Vivid Black
Ogre3239 is offline
post #3 of 13 (permalink) Old 02-19-2012, 08:33 PM Thread Starter
Thanks , I think I ended up finding a pretty good write up on the ole interwebs after much looking. Maybe I'll post it after a read thru .
post #4 of 13 (permalink) Old 02-19-2012, 08:59 PM
Ride Hard
DSMITH's Avatar
Windshield screws
Two mids screws each side
Two lower screws each side
Don't take the wind deflector screws off.
Make sure you are holding the fairing after all the screws are out.
Disconnect the headlight connector
Good luck
DSMITH is offline
post #5 of 13 (permalink) Old 02-19-2012, 09:04 PM
when did it start 4u
Jacket4256's Avatar
^^^^ he seems to be talking about the inner not the outter fairing
2004 Sportster
2012 HD Road Glide Ultra
2006 GTO with idle problem
2011 Subaru OB (DD)
A great man once said
Jacket4256 is offline
post #6 of 13 (permalink) Old 02-19-2012, 10:10 PM
Seor Member
Vettster's Avatar
Location: Veracruz, Ver. Mexico (I rarely take off my flack jacket. ;-)
Check your service manual.
Step by step instructions in there.
Ride Safe,
Vettster
2010, FLTRX W/ SE 120R.
Welcome to the forum. One of the best places on Al Gores interweb.
If you are new, why not mosey on over to the New Member section and tell us a little bit about yourself and your bike.
IBA#44072
Vettster is offline
post #7 of 13 (permalink) Old 02-19-2012, 11:23 PM
IAFF local 845
mab864's Avatar
+1 on the service manual. Best $60 you'll spend. I just took my outer fairing off for the first time and I'm sure I wouldn't have found the two screws under the lower triple clamps. It's worth the $ to keep from breaking parts and save frustration.
'12 Street glide... adding miles.
mab864 is offline
post #8 of 13 (permalink) Old 02-20-2012, 08:13 AM
SCHMIDTY's Avatar
Swapping the inner fairing is a fair amount of work . The best tip I can give is to take pics all along the way .
... Cover the front fender and remove the windshield and outer fairing and put them out of the way .
... Remove the passing lamps and put them out of the way .
... Disconnect the radio wiring then remove the radio and put it out of the way .
... Disconnect the throttle and clutch cables from the handlebar perches then pull them thru the front of the inner fairing and let hang .
... Cut the tie straps securing the wiring to the vertical fairing supports , the two black brackets the 4 radio screws bolted to . Remove the remaining bracket screws .
... Remove the 4 bolts that secure the inner fairing to the fork legs .
... Unplug all the wiring harness connectors .
... Move the inner fairing around to loosen it up while spreading the bottom wings and pulling them around the fork legs .
... At this point the fairing should be loose enough to slide up and out , some finesse and wiggling will be required .
... Transfer gauges etc. to the new inner fairing .
... Repeat in reverse order to reinstall the new inner fairing .
... I would suggest using painters tape at critical points so the new paint job doesn't get damaged .
... Hope you've been taking pictures along the way !!!
... If I missed any fine points I'm sure that someone else that's done the procedure will chime in .
SCHMIDTY is online now
post #9 of 13 (permalink) Old 02-20-2012, 08:34 AM Thread Starter
Perfect, just what I was looking for, not just the instructions, but pointers so as not to trash my ride, thanks guys!
post #10 of 13 (permalink) Old 02-20-2012, 08:54 AM
Just so you new guys know this forum policy on bootleg service manuals . . . .
http://www.harley-davidsonforums.com...r-manuals.html
Tucson_Tim is offline
