Blowing White Smoke at Cold Start - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 13 (permalink) Old 12-01-2008, 09:15 PM Thread Starter
Corndog's Avatar
I upgraded my 2005 FLHTI. My buddy and I installed new cams (Andrews 21G), 95ci pistons (Screaming Eagle & Screaming Eagle gaskets), and a power commander (downloaded close map to match my set up). Had the cylinders bored to match the pistons and the heads cleaned and new seals installed. Everything else was left stock. All was good for the first 500 miles. Now Im getting white smoke coming out of the exhaust at cold start-up. It last for a about 30 seconds and then goes away. Too much smoke to be condensation. Everything else is okay, no funny smells, bad noise, or bad throttle response. Does anybody have any idea? Maybe bad valve stem seals on the heads?
Corndog is offline
post #2 of 13 (permalink) Old 12-01-2008, 09:35 PM
Old Member
Hawkmann's Avatar
Images: 9
White smoke from condensation occurs at startup on a cold morning, and is most pronounced at idle, until the engine heats up enough for it to go away.
War does not determine who is right - only who is left..
Hawkmann is offline
post #3 of 13 (permalink) Old 12-02-2008, 11:32 AM
MikeYork5's Avatar
Well since you're not water cooled - rules out a blown head gasket, and it doesn't smell - sounds like good ole condensation to me.
'When if's and but's are candy and nuts, oh what a world it will be"
THE MAIN THING... IS TO KEEP THE MAIN THING THE MAIN THING.
MikeYork5 is offline
post #4 of 13 (permalink) Old 12-02-2008, 01:38 PM
STAND AND FIGHT!
Nathang's Avatar
Images: 223
Ya think oil entering the cylinder from a valve guide seal leak on an intake valve
might mix with incoming gasoline well enough to burn so clean it didn't smell
much or look like oil smoke?
Maybe after the valves get hot, the leak would stop?
If that was true, you could probably tell it soon, by oil consumption, and ash on your plug tips.
Nathang is online now
post #5 of 13 (permalink) Old 12-02-2008, 07:32 PM
I vote valve seals
05's were noted for valve seal issues...my .02
Geoff1200 is offline
post #6 of 13 (permalink) Old 12-02-2008, 07:55 PM
Just passing thru
EZE RIDER's Avatar
Images: 118
Agreed.
Check the rear cylinder spark plug for fouling. My buddy had the same issue with his 05 ultra and it fouled out the rear plug but its a piece of cake to get to. He got to the point before he had it fixed that he would change out the rear plug a couple of times on a long ride.
Like Dave said having the upgrade done throws a monkey wrench in the works.
RIDE ON!
2007 VRSCDX since
November 28 2006
Pics
EZE RIDER is offline
post #7 of 13 (permalink) Old 12-02-2008, 08:27 PM Thread Starter
Corndog's Avatar
It was in the mid to high 70's when I started the cold motor. Could it be condensation at these temps? I'm still thinking valve oil seal issue.
Corndog is offline
post #8 of 13 (permalink) Old 12-02-2008, 08:30 PM Thread Starter
Corndog's Avatar
Thanks! I only have about 60 miles on her since I noticed. I'll keep an eye on the oil and I'll check the plugs in a few.
Corndog is offline
post #9 of 13 (permalink) Old 12-02-2008, 08:43 PM
أنا كافر
Kainam's Avatar
Images: 150
What color were the valve guide seals you put in? PN #18094-02 (all black) are known to have a leak issue. These were superceeded by PN 18094-02A (black with orange top) which are supposed to cure the leak.
Mala Ipsa Nova
Psalm 144:1 Luke 22:36
'05 Carbed Night Train
111 rwhp, 112 rwtq
Best 1/4 ET 12.557s
Best 1/4 MPH 108.59
Kainam is online now
post #10 of 13 (permalink) Old 12-02-2008, 08:47 PM Thread Starter
Corndog's Avatar
Originally Posted by Dave63 View Post
It's possible.... definitely possible, Nathan. Usually worn valve giudes do this, although I'd find it hard to believe that his seals are shot in 3 years. (Not saying it's not possible, though.) Also, according to his words, they went bad in 500 miles, right after the upgrade. Too coincidental, to me.
I had the heads cleaned and new seals installed with the other upgrades. I had an old timer wrench do it. I would put money on it that it was a defected valve seal (because I had him install the seals with the noted issues) before it was poor work of my wrench.
In this case, it appears to have started AFTER the upgrade. (500 miles after) It makes me wonder about ring-gap, and if there's a cylinder that's not sealing, or leaking down. I'd suggest a compression test of both cylinders, dry and wet methods.
We measured twice and cut once before we installed the rings on the pistons. We had two eyes on the gap of the rings. Hopefully this is not the issue. I'll look into the compression test. I assume it would let me know if I has a cylinder not sealing?
FYI.....smoke at start up can also be caused by an overly soaked airfilter element, that's draining oil vapors overnight, (bike leans to the left) into the air intake. If you've done little to anything to vent off some of the blow-by that you get on these engines at higher speeds, this is a distinct issue. Enlarging the return holes next to the heads and venting the oil vapors somewhere OTHER then into the intake can avoid it as well.
I just cleaned my air filter before I put one mile on the upgrade. Ran fine for 500 miles. I don't think this is the issue but I'll take a look at it. Hopefully I'm not blowing excessive oil in the air box.
Corndog is offline
