trike or sidecar - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 20 (permalink) Old 05-30-2012, 07:22 AM Thread Starter
trike or sidecar
i was thinking of buying a trike.what are they like to ride.i hv a roadking classic and was thinking a side car.can a side car b removed.are they hard to manage.any advice welcomed.
rockie is offline
post #2 of 20 (permalink) Old 05-30-2012, 10:08 AM
RobsUltra's Avatar
Good quality trikes are awsome but expensive. They are a different animal than a Roadking simply because they have NO LEAN in corners. I test rode a 2011 UC trike and just could not wrap my mind around no leaning thru corners. Its a very scary feeling but I'm guessing it's a learned skill.
Side cars are an entirely different breed themselves. You need to make some modification to the front end of your bike to accomadate a side car. I believe a suspension dampner for the front forks as well as increasing the length of the front forks to accomadate the car. I suggest you do a lot of research before attaching anything to your scooter. There are a lot of quality kits out there as well as a lot of unsafe kits available.
Ride safely and good luck with your research friend.
RobsUltra is offline
post #3 of 20 (permalink) Old 05-30-2012, 10:24 AM
PRR_K4's Avatar
Images: 11
might be hard to find a Harley sidecar since they stopped making them a few years ago, and more than likely, if you do find one, you will pay top dollar for it.
PRR_K4 is offline
post #4 of 20 (permalink) Old 05-30-2012, 11:27 AM
Seor Member
Vettster's Avatar
Location: Veracruz, Ver. Mexico (I rarely take off my flack jacket. ;-)
Trikes are fun!
Rob is correct. They do take a little time to get used to. You can't lean in the curves. This can freak some people out at the start.
Think if it as you ride a bike and drive a trike.
Ride Safe,
Vettster
2010, FLTRX W/ SE 120R.
Welcome to the forum. One of the best places on Al Gores interweb.
If you are new, why not mosey on over to the New Member section and tell us a little bit about yourself and your bike.
IBA#44072
Vettster is offline
post #5 of 20 (permalink) Old 05-30-2012, 03:59 PM
Since I own and drive a sidecar and have for a while,I'd say sidecar. I have not tried a modern Trike,only a servicar. A sidecar can "fly" on tight right turns,but a trike can "fly" right or left. I owned and drove a H-D sidecar when I tried the servicar,for me no thanks,It purt near skeerd me.
windy is offline
post #6 of 20 (permalink) Old 05-31-2012, 04:25 AM Thread Starter
thanks for advice guys.im from ireland and have only seen side cars and trikes on utube.not a demand over here.what i realy want is something my better half can feel confident on.any more advice wld b much appreciated.
rockie is offline
post #7 of 20 (permalink) Old 05-31-2012, 04:26 AM
Side car. I'd get a sidecar in a heartbeat if I had the garage space. I'd likely put all my stuff in it and run away from home too.....
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #8 of 20 (permalink) Old 05-31-2012, 04:39 AM Thread Starter
rockie is offline
post #9 of 20 (permalink) Old 05-31-2012, 05:15 AM Thread Starter
thanks 4 reply dave 63 but i want to bring my wife not run away from her,although its a nice thought.can u take side car off and wld new parts like dampers make a diff to the ride of my roadking.nt want to do that.
rockie is offline
post #10 of 20 (permalink) Old 05-31-2012, 05:23 AM Thread Starter
new posts
how do i post messeges to mew posts.i keep sending them to active topics.
rockie is offline
