S&S v111 installed in my '97 Roadking - Page 4 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 11-21-2012, 01:04 AM   #31 (permalink)
I too am confused at this point. Surely S&S sent back the same motor if nothing was found to be amiss in it. You say you still have the same issues/sounds and nobody can figure out what it is?
HandOverFist is offline   Reply With Quote
Old 11-25-2012, 08:09 PM   #32 (permalink)
I'd like to see the primary drive parts. Was anything mis-aligned?
CharlieB53 is offline   Reply With Quote
Old 11-26-2012, 10:58 AM   #33 (permalink)
So do you know what the dealer fixed when the engine was re-installed?
jeffb is offline   Reply With Quote
Old 12-09-2012, 04:59 AM   #34 (permalink)
Sad to say overseas we have found the S&S warranty pretty poor. You must take the motor to the dealer that installed it. If they are gone then you have to ask the importer (presuming it was imported by a distributor) and ask them to look into it. Another dealer or importer won't touch it. If car dealers/manufacturers behaved like that there would be an uproar.
calafradulistic is offline   Reply With Quote
Old 12-10-2012, 03:01 PM   #35 (permalink)
I'm back, as I said before, it was the Harley dealer. They screwed the whole job from the start.
I got my bike back this past Friday, 12-7, after they kept it almost a month after getting it back from S&S. It coughed, backfired and ran like a John Deere tractor. I got it home and looked on youtube on how to adjust the super e carb and adjusted it. I put on a set of Vance & Hines slash cut rounds and when I loosened the clamp the flange on the pipe connecting to the exhaust manifold almost fell off. the screws were loose.
By the way, S&S determined that when this dealership installed the engine they finger tightened the spark plugs, and that is why the engine was making the god awful scraping noises.
It was not S&S that was the cause, it was an incompetent dealership that I had done business with for 25 years.
Yes, they just sent the engine back to me, after adjusting the carb it runs real nice, but I'm working with S&S with possible leaks on the intake manifold or somewhere around the carb. This has been a nightmare. And Oh, by the way, they charged me $400 for the R&R that they caused.
29roadking is offline   Reply With Quote
Old 12-10-2012, 03:06 PM   #36 (permalink)
Originally Posted by dirtdobber View Post
This has me confused. It is still under the 12 month warranty. So, is this a replacement engine for the one that was in the 96 in the first place?
I have a 106 in a Dyna and it has been nothing but fast and with no issues. Hope it works out
dd
There was nothing wrong with the engine in the first place, it was the idiots at the Harley Dealership. I'm a pretty good mechanic, but never thought anyone would not tighten the plugs up. Daum, they anylized the enging for 2 days before S&S decided to send a box and pick it up. It took them 3 weeks to remove the engine to send it back. S&S kept it 3 and 1/2 weeks, sent it back then Doug's took almost 4 weeks to install it. The I had to adjust the carb, they didn't know how to.
Old 12-10-2012, 03:07 PM   #37 (permalink)
They've been pretty damn helpful to me.
Old 12-10-2012, 03:09 PM   #38 (permalink)
No, but the mechanic was maladjusted.
Old 12-10-2012, 03:50 PM   #39 (permalink)
dd
I removed the evo80 back in the late summer and replaced it with the S&S v-111. Then the problems started. It was a comedy of errors from all sources, with the exception of S&S.
Old 12-10-2012, 05:44 PM   #40 (permalink)
Good to hear the S & S is good. I have NO faith in the greedy HD dealers. The only thing I buy from them is a t-shirt.....and those are SERIOUSLY overpriced.
GHBiker is offline   Reply With Quote
