engine temp sensor - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 11-06-2012, 09:05 AM   #1 (permalink)
engine temp sensor
Good day all! Can some one tell me what the et sensor does? My 03 ultra has a loss of power when it gets hot and spits and sputters and almost dies. Thanks and REMEMBER TO GO VOTE OR DON'T BITCH!
maddan is offline   Reply With Quote
Old 11-07-2012, 07:12 AM   #2 (permalink)
SCHMIDTYS's Avatar
Simplified, the ET sensor tells the ECM what the temp of the front head is. With that signal the ECM changes timing and fuel delivery to match a map stored in the ECM EEPROM.
If there aren't any stored codes which happens sometimes with a failing ET sensor you can do a simple test. Determine how long it takes untill the engine starts acting up. After the engine cools back down remove the sensor from the head and plug the electrical connector back onto it. Locate the sensor away from the engine heat and start the engine and run it untill it's hot. If the engine doesn't act up in the same amount of time it's a good bet the sensor is failing.
Old 11-07-2012, 07:15 AM   #3 (permalink)
Greasy Member
As well, I'd also check intake seals for leaks. Bike runs ubber rich when cold and can mask intake seal leaks. Once warm, the AFR is too lean. No adjustments on 2002-2006 models. Only cold/warm maps. Could be either the temp sensor or intake.
Football Season is over....
Praise the Lowered!
11 year A.M.A. member.
4 year PA ABATE member.
Old 11-07-2012, 07:20 AM   #4 (permalink)
SCHMIDTYS's Avatar
Also with the sensor removed the engine idle will remain high, in cold idle mode.
Old 11-07-2012, 07:39 AM   #5 (permalink)
THE ROAD's Avatar
Images: 11
Ahh sensors , ya gotta love failing sensors on ALL the newer Harley's . Sometimes newer doesn't equate to better , especially when it comes to Harley's !
THE ROAD is offline   Reply With Quote
Old 11-07-2012, 07:51 AM   #6 (permalink)
True so true..
webco2 is offline   Reply With Quote
Old 11-07-2012, 09:00 AM   #7 (permalink)
'01 FLHTCUI, 103K+MI
Tom31w's Avatar
By reading this thread I just learned something today, another day not wasted...
The object in life is not to arrive in a pristine well taken care of body; rather it is to slide in sideways, body thoroughly used up, a drink in one hand and chocolate in the other, screaming "That was one HELL of a ride!!!"
Tom31w is offline   Reply With Quote
Old 11-07-2012, 01:49 PM   #8 (permalink)
thanks gents i'll give it a whirl!!
