floor boards - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 11-24-2012, 11:50 AM   #1 (permalink)
buddy75's Avatar
floor boards
I have a set of floor boards on my 06 SG, I want to take them apart to powder coat them. I just not sure on the inserts. I see that they kind of just push them. is there a way to get them back off with wrecking them...any tips?
buddy75 is offline   Reply With Quote
Old 11-24-2012, 01:52 PM   #2 (permalink)
Greasy Member
WD40 the stubs that stick through and use a dull instrument. Most times, you just cut them to replace them. They can be worked out, but be careful and use lots-O-lube.
Pretty much the same as with anything else in life,..........
Football Season is over....
Praise the Lowered!
11 year A.M.A. member.
4 year PA ABATE member.
Old 11-24-2012, 02:11 PM   #3 (permalink)
tryanm's Avatar
I used the wd40 method on mine and they weren't too bad at all to pop out. Lubed them up and used needle nose to squeeze the rubber together and get them started back through the holes and then a little pressure and patience.
Sent from my DROID4 using Motorcycle.com Free App
1992 FLHS
tryanm is offline   Reply With Quote
Old 11-27-2012, 02:18 PM   #4 (permalink)
SunCruise's Avatar
When I changed my inserts to a different style I used 2 long flat screwdrivers to pop the old one off.
Pressing the new ones on I used lots of dish soap and went on easy. Had I used soap for removal it would have been easier still.
SC
'09 FLHRC
103/se204
TTS MasterTune
V&H True Duals
SunCruise is offline   Reply With Quote
