2000 RK foglights - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 11-28-2012, 12:15 AM   #1 (permalink)
chop1457's Avatar
2000 RK foglights
ok ,I need the GURU'S help..I have a 2000 RK I bought a complete set of foglights,bar and turn signals from a 2005 RK the plugs are different so I know its not gonna be plug in but I do have the plugs from my switches and the plugs on the light ...my question is how do I wire it to work
chop1457 is offline   Reply With Quote
Old 11-28-2012, 05:44 AM   #2 (permalink)
Hockey my Life
JPWendtinc's Avatar
Images: 17
You're going to have to
1. Buy the service manual
2. Buy the correct connectors for the light side and install the pins in them
Or
3. Cut the pin connectors off of both sides and either butt splice or solder the wires together. Be sure to install shrink tubing over all connections.
The wiring section of your manual will tell you what color wire is for what light. If the colors don't match the light bar it should be easy enough to trace them.
JPWendtinc is offline   Reply With Quote
Old 11-29-2012, 09:59 AM   #3 (permalink)
chop1457's Avatar
got'er done thanks took about an hr
Old 11-29-2012, 10:09 AM   #4 (permalink)
Greasy Member
Usually you can color match the wires if the plugs are different........
Football Season is over....
Praise the Lowered!
11 year A.M.A. member.
4 year PA ABATE member.
Old 11-30-2012, 01:14 AM   #5 (permalink)
chop1457's Avatar
thanks guys I got it done ....have a great holiday I'm leaving for FL for 2 weeks christmas with family
