Skating - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 12-06-2012, 12:34 PM   #1 (permalink)
Unhappy Skating
I bought a 2007 street glide with 30k on it. The bike seems to skate around alot on the road when going 55 or faster need help.
johnfiess is offline   Reply With Quote
Old 12-06-2012, 12:46 PM   #2 (permalink)
Stay off the gravel roads.
Old 12-06-2012, 12:49 PM   #3 (permalink)
Rhino40's Avatar
If it were my bike, and the problem persisted after verifying proper tire condition and pressure, i would look at upgrading the suspenssion. I did that on my Ultra and it made a world of difference, especially holding my line in higher speed turns. Good Luck.
Rhino40 is offline   Reply With Quote
Old 12-06-2012, 01:33 PM   #4 (permalink)
Union Ironworker
000RK's Avatar
Thumbs up
good place to start
I'd also be checking wheel alignment...if the bikes been in an accident (even a small fender bender) and the frames bent it could "skate"......you can do that with a couple of straight 2x4's.
If women are so good at multitasking how come they can't have a headache and sex at the same time?
000RK is offline   Reply With Quote
Old 12-06-2012, 01:36 PM   #5 (permalink)
Rhino40's Avatar
Originally Posted by 000RK View Post
good place to start
good call, very possible that someone adjusted the belt tension and tightend the rear wheel slightly cocked.
Old 12-06-2012, 01:46 PM   #6 (permalink)
DO YOU HAVE THE SERVICE MANUAL?
Have you checked tire pressure?
FRONT AND REAR?
Tire Wear pattern?
FRONT AND REAR?
Wheel Alignment?
Wheel Play? - wheel bearings?
Does it have a lowering kit?
Shocks secure? - what pressure are they set at?
What about swing arm bushings?
How about the front end? Fall away test done?
Old 12-06-2012, 02:12 PM   #7 (permalink)
Rookie for life
Rockhead261's Avatar
THAT DOES IT! Link, I am officially in LOVE with your avatar!
Rockhead
2012 FLHTCUI, White Hot Pearl, Master Tuner, DIY gutted headpipe, H-D heated grips, 1" floorboard extenders, VStream, HDPD+, J&M Rokkers (thanks, Falc!)
2004 FLHTCI, Solid Blue - sold
1998 FLHTCI, Laser Red Pearl - traded
1996 FXDL, black/violet teal - traded
1992 XLCH1200, black - sold
Rockhead261 is online now   Reply With Quote
