hayden bt07 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 12-18-2012, 04:13 PM   #1 (permalink)
hayden bt07
any problems with the new design with the heavier springs,likes,dislikes,problems someone was saying the chain was really tight.
hardheaded is offline   Reply With Quote
Old 12-19-2012, 08:48 AM   #2 (permalink)
bump
Old 12-19-2012, 09:31 AM   #3 (permalink)
07 FXSTC ;)
Rohan's Avatar
Buddy of mine has one. Says the shifts are smoother, clunking is almost non-existent. He likes it. I may try one on my Street Glide. $105 seems a little steep to me though. I would think 60 or 70 at the most but I guess that's the way it is.
-Rohan
Rohan is offline   Reply With Quote
Old 12-19-2012, 09:44 AM   #4 (permalink)
#1 Si Robertson Fan
City Chicken's Avatar
Is it designed to offset some of the damage that can be caused by crank pin run out? Or does it just make shifts smoother?
"First it's pretty tires, then it's pretty guns...next thing you know, you're shaving your beard and wearing capri pants."
- Si Robertson
'12 FLHTK Ultra Limited, Vivid Black, Stage II (Rush True Duals and Slip Ons, SE-204 cams, SE/K&N AC, PCV, SE Push Rods & Lifters), Progressive Monotubes and 444s
City Chicken is offline   Reply With Quote
Old 12-19-2012, 07:26 PM   #5 (permalink)
07 FXSTC ;)
Rohan's Avatar
All it does is keeps "correct" tension on the chain at all times. Instead of being a stationary plate for the chain to ride on, it looks like it might use spring tension to keep just enough slop out of the primary chain to avoid "clunking" into gear caused by the slop in the chain being snapped out once the bike is put into gear. I can't see paying that much for it though and now they are saying that in January the price is going up to $130. Honestly, as long as you keep your chain tension within the correct specs according to the manual you should never have any problems other than normal wear of the plastic shoe. I have a 1973 XLH and a 1976 FLH and I've never had an issue with either one other than plastic shoes wearing down.
As far as crank pin run out, I've not ever had it happen but I've seen guys with high HP motors weld theirs in.
-Rohan
Old 01-03-2013, 01:35 PM   #6 (permalink)
Old School
Slick02's Avatar
The newer bikes have a spring loaded ratcheting tensioner that keeps the primary chain to tight leading to bearing/seal problems, I actually just recieved the Hayden in the mail a couple of days ago and installing it this weekend..and the price doesn't bother me as long as I avoid repairs/downtime issues...(thats what the H-D stands for,, Hundred Dollars)
03 100th anniv. black/silver bagger/SOLD
2013 110th anniv. black/bronze bagger
S/E Ventilator air cleaner
Drago's 2 into 1 exhaust
TTS tuner
CVO adjustable rear shocks
C&C custom Sport Touring seat
Detachable hardware/tourpack
Cycle Vision LED taillight/tag mount
J&M Audio 7.25 speaker upgrade
lots misc chrome and enough stuff to keep my wife upset and always more to come
Slick02 is offline   Reply With Quote
Old 01-03-2013, 02:05 PM   #7 (permalink)
Originally Posted by Slick02 View Post
The newer bikes have a hydraulic ratcheting tensioner that keeps the primary chain to tight leading to bearing/seal problems, I actually just recieved the Hayden in the mail a couple of days ago and installing it this weekend..and the price doesn't bother me as long as I avoid repairs/downtime issues...(thats what the H-D stands for,, Hundred Dollars)
i got a 2012 and they are not hydraulic tensioners in these bikes they are spring loaded ratching devise's, or should i say a tightner.gets tighter and never loosen's up.
Old 01-03-2013, 04:17 PM   #8 (permalink)
SwampRat
JayFL459's Avatar
Images: 21
You will be glad you did went to the Hayden at 40,000 miles on my 09 Ultra and for the next 28K only thing was wishing had done it sooner smoother shifting and less noise ..
2000 FXR4, Stage 2/ 2012 Victory XC
JayFL459 is offline   Reply With Quote
Old 01-04-2013, 12:22 PM   #9 (permalink)
Old School
Slick02's Avatar
Hardheaded, I stand corrected sir..thank you
TTS tuner
Old 01-04-2013, 04:21 PM   #10 (permalink)
let us know how your install goes and what you end up with as a measurement between the shoe and plate. i'm gonna order one of these shortly.
