Leaks after switching from dino to synthetic - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 12-26-2012, 05:58 PM   #1 (permalink)
I've been looking through the forum and searching but haven't found a clear answer. I've heard of folks developing leaks after the switch and the opposite saying those problems have been worked out. Just wanted one more check before I do so. I have a new to me 04 Electra Glide with 28,000 on her, I ride every day and while it's cold now it will be hot here in the South before we know it and I like the aspects of the synthetic. Has anyone had any problems with the switch?
mmbikemike is offline   Reply With Quote
Old 12-26-2012, 07:04 PM   #2 (permalink)
I swapped to SYN3 at the 1K service on my 2012 FLTRX.
No problems yet but I'd think if a leak developed it wouldn't be due to the synthetic oil, most likely the gasket was going to leak anyway.
Old 12-26-2012, 07:41 PM   #3 (permalink)
Go Army!
ClassichHarley's Avatar
No issues here on either 08 Heritage or 2012 Switchback when I switched to SYN3 in the both Oil and Primary cases. Went with Red Line in the Transmission and no issues there either.
“Courage is fear holding on a minute longer.” -General George Patton Jr.
2008 FLSTC with SE Stage II 103ci Big Bore, 255 cams and V&H Big Shot Longs
Stock: 79.43 ft-lbs of torque / 66.41 hp
SE Stage I: 85.57 ft-lbs of torque / 72.44 hp
SE Stage II: 108.22 ft-lbs torque / 88.13 hp
ClassichHarley is offline   Reply With Quote
Old 12-26-2012, 07:51 PM   #4 (permalink)
Luke 22:36
Kainam's Avatar
Images: 136
The instances of motors developing leaks after switching to a synthetic oil are pretty old, not the problem now as when synthetics first came out.
What happened was on motors that had many miles (way more than 28,000), were run on older dino oil that didn't have the detergents that modern oils do. This allowed sludge to build up, and this sludge is what was actually keeping the motor from leaking. Then when they switched to synthetic oil with a better detergent package, it cleaned out the sludge and thus showed evidence of bad rocker box gaskets that the sludge was masking.
Even today's dino oil has a better detergent additive package than the dino oils used when synthetic oils first came to market.
There's drones in my livingroom!
'05 Carbed Night Train
111 rwhp, 112 rwtq
Best 1/4 ET 12.557s
Best 1/4 MPH 108.59
Kainam is online now   Reply With Quote
Old 12-26-2012, 07:56 PM   #5 (permalink)
THE ROAD's Avatar
Images: 11
I'd stay away from royal purple if your concerned about developing oil leaks . Ask me how I know !
THE ROAD is offline   Reply With Quote
Old 12-26-2012, 08:00 PM   #6 (permalink)
Señor Member
Chief Illiniwek's Avatar
Images: 55
Kainam's explanation is the only story I could swallow. Otherwise, I'd say leaks occurring when changing fluids is either coincidence or nonsense.
A sludgy, high-miler impacted by detergents sounds reasonable, though.
2011 Road King Classic, Python slip-ons, Stage 1 SE a/c, Power Commander V
Chief Illiniwek is offline   Reply With Quote
Old 12-27-2012, 08:00 AM   #7 (permalink)
03 CVO RK
GotGold's Avatar
I had the exact same concern as you...and a bad experience with a low mileage Explorer..leaked like a sieve after the change.. but that was in 1993. When I bought this bike in Feb it had 7,000 miles on it, not very well cared for. I changed oil and filter and ran it another grand on dino (to clean it out). I then switched to Amsoil. That was 5,000 miles ago. No leaks, I'd do it again in a heart beat, I like the protection in the heat. Just my .02
"Our lady of blessed acceleration don't fail me now."--- Elwood
GotGold is offline   Reply With Quote
Old 12-27-2012, 08:05 AM   #8 (permalink)
Millwright
petew's Avatar
Not to worry, so long as U use HD's Syn3...
103" w/Race Kit,Stage IV 117HP 111TQ
SE 259E Cams
SE Heavy Breather AC (Scott's modified)
SE Race Tuner
V&H Power Duals & Hi Outputs
SE CNC Heads 10.62/1 w/SE 58mm TB
John Scott port matching
Renegade Racine wheels. 21x3.5/ 17x6.25
http://www.harley-davidsonforums.com...845-petew.html
petew is offline   Reply With Quote
Old 12-27-2012, 08:22 AM   #9 (permalink)
No problems with the change.
webco2 is offline   Reply With Quote
Old 12-27-2012, 09:08 AM   #10 (permalink)
Greasy Member
As stated: The oil isn't what caused the leak, rather sludge and a weak seal.
Football Season is over....
Praise the Lowered!
11 year A.M.A. member.
4 year PA ABATE member.
