Compensator Sprocket troubles - Page 2 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #11 of 47 (permalink) Old 08-14-2009, 03:16 AM Thread Starter
Longo's Avatar
Installed SE compensator, now I'm in business!
Longo is offline
post #12 of 47 (permalink) Old 08-14-2009, 04:45 AM
Good to hear....
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #13 of 47 (permalink) Old 08-15-2009, 01:53 PM
1 member biker club
oldbag's Avatar
Give us some detail on how the SE compensator changed you bike.
'09 Sweet Glide
Vivid Black
TTS MasterTune w/Twin Scan ll+
oldbag is offline
post #14 of 47 (permalink) Old 08-15-2009, 07:48 PM Thread Starter
Longo's Avatar
The motor doesn't vibrate as much as before, it starts right up without any rattle/bang noise or popping sound. The bike is smoother going down the road and revs better. But mostly got rid of the primary rattle while cruising down the road.
Longo is offline
post #15 of 47 (permalink) Old 12-06-2010, 06:57 PM
SE compensator
I have an O8 FLHTC 33,000+ miles. It has a hard time starting and has a rattle in the primary that sounds like piston slap. But the noise is inside the primary. The dealer replaced the starter when it quit turning over the engine. and it sounds like it is backfiring when it tries to start when at normal temp. Several people tell me to upgrade to the SE part. But I think Harley should Pay for the repair. The bike is under ESP warranty. Maybe I am just being a Horse's a--. But I think an engine should start. mb
Mike Bryant is offline
post #16 of 47 (permalink) Old 12-06-2010, 08:34 PM
Mississippi Cajun
kd5cqt's Avatar
I have a close friend who had a similar problem with his Ultra. It ate starters. I believe he had about 5 starters changed out. HD says that the fix is to go to the SE compensator, but as I understand it, they will not cover it under warranty because it is an engineering matter and not a defect in material or workmanship (talk about spltting hairs). BTW, MOCO paid for the starters and labor, but still refused to buy the SE. Go figure.
I am told (Schmidty help me here) that the '11s come stock with the SE compensator. I sure hope so cause that's what I'm riding.
USAF Veteran, PGR Member, Retired Old Fart! 2015 Electraglide Ultra Limited
Hey, immigrants: Learning English and assimilation to American culture is NOT a suggestion!
kd5cqt is online now
post #17 of 47 (permalink) Old 12-07-2010, 06:09 AM
SCHMIDTY's Avatar
The 11s come with the SE comp. assy. . Not called SE anymore tho as it's now a stock component .
SCHMIDTY is online now
post #18 of 47 (permalink) Old 12-07-2010, 12:36 PM
wingfoot's Avatar
Comp
I just had mine replaced under warranty. The service manager says due the high volume of bad comps they were directed to replace the comp with the SE comp. BUT they are charging the price difference of about $80. in the two comps.
It made a big difference in the way my bike started, shifted, hot start jickback and no more noise from the primary.
Do It....
wingfoot is offline
post #19 of 47 (permalink) Old 12-08-2010, 05:10 AM
'10 RK had a lot of "slack" when getting on or off the throttle. Replaced the comp myself as I don't have the dealer touch my bike. Well worth the $250.00 and the satisfaction of knowing it was done right.
NELS is offline
post #20 of 47 (permalink) Old 12-09-2010, 06:39 PM
There have been lots of threads on various forums re the SE compensator. Only read one less than enthusiastic review, and he said he found very little difference between new and old. Perhaps he had the one out of 1000 stock comps that met or exceeded design specs. I have 15,000+ on the SE comp on an 08 RK, wouldn't go back.
btsom is offline
