shifter pawl adjustment - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 17 (permalink) Old 04-30-2012, 02:35 AM Thread Starter
gorilla glue tuff
Frosty4232's Avatar
okay i've searched high and low online and through my manual on how to adjust my shifter pawl. i know what needs to be done and how to do it but my problem is i cant find this jam nut and allen head bolt and its driving me insane. everything ive found shows where the jam nut and allen head are but on my bike its just an allen head screw with no jam nut and in the manual it says "Screw (not an adjuster)" am i missing something here??? i want to tear what hair i have left out trying to figure this out!
Frosty4232 is offline
post #2 of 17 (permalink) Old 04-30-2012, 02:36 AM Thread Starter
gorilla glue tuff
Frosty4232's Avatar
its a 2001 super glide if that helps any.
post #3 of 17 (permalink) Old 04-30-2012, 04:40 AM
Dan89flstc's Avatar
2001and later do not have the adjustable centering pin for the shifter pawl.
Dan89flstc is online now
post #4 of 17 (permalink) Old 04-30-2012, 05:03 AM Thread Starter
gorilla glue tuff
Frosty4232's Avatar
Is there any way to adjust it? I have the top cover off and I can see that's it is definitely off. In 3rd gear it's all the way forward instead of in the middle
post #5 of 17 (permalink) Old 04-30-2012, 06:43 AM
SCHMIDTY's Avatar
Like was said , there's no adjustment screw . The shift drum isn't adjustable either . Make sure the 4 hold down bolts are tight too . There might be a bent shift fork but that would be evident looking at them with the cover off .
Your service manual shows the relationship between the gears and shift forks and where they should locate in each gear .
SCHMIDTY is online now
post #6 of 17 (permalink) Old 04-30-2012, 07:34 AM
Actually Dan, I believe it's ANY TC trans, only Evo and older. I could be wrong...
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #7 of 17 (permalink) Old 04-30-2012, 08:47 AM Thread Starter
gorilla glue tuff
Frosty4232's Avatar
well thats a bummer. i looked at the shift forks and they look fine. i'm lost here as to whats going on with this trans. im half tempted to just rebuild the thing
post #8 of 17 (permalink) Old 04-30-2012, 10:34 AM
I just read in American Iron that the adjustable centering pin can be installed in the later trans. I'm pretty sure the gear set has to come out and the shifter ratchet removed, but realistically it can be done in an afternoon. The biggest deal is pulling the inner primary bearing off the input main shaft. You can do this by CAREFULLY cutting down lengthwise on the inner bearing with a cut off wheel and then cracking it with a chisel, it falls right off. Make sure not to cut the shaft. A new one is cheap and can be tapped on, no special tools. The trans doesn't have to be removced from the bike.
chris_lacey is offline
post #9 of 17 (permalink) Old 04-30-2012, 10:58 PM Thread Starter
gorilla glue tuff
Frosty4232's Avatar
Thanks for the info Chris. I was actually thinking last night about doing that last night but wasn't sure if it was possible
post #10 of 17 (permalink) Old 05-01-2012, 06:30 AM
SCHMIDTY's Avatar
So what's wrong with your trans anyways ??? It's not shifting good or what ???
