Evo Trans leak behind primmary! - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 13 (permalink) Old 07-15-2012, 09:23 PM Thread Starter
So on my '94 wide glide I got a tranny leak behind the primary, I am assuming the seal right behind the drive pulley. How big of a job is this and what special tools would be needed? Also are any nuts reverse thread? Plus if anyone knows the cost involved and what are the better seals and gaskets too use.
Thank fellas.
94FXDWideGlide is offline
post #2 of 13 (permalink) Old 07-16-2012, 04:29 AM
Tools: Special socket to remove front sprocket. (Super deep)
Clutch basket nut is reversed (lefthand) thread.
3-4 hour job.
Need to yank entire inner primary, clutch, compensating sprocket, starter (unbolt) and remove starter gear and jackshaft.
OEM gaskets/seals are fine.
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #3 of 13 (permalink) Old 07-16-2012, 06:57 PM Thread Starter
Thanks Dave, My neighbor works for harley as a parts manager, i'll see if he can borrow the socket from the shop.
post #4 of 13 (permalink) Old 07-16-2012, 08:06 PM
Ardeum's Avatar
3-4 hour job.
Dave... You are a good dude.
'09 Ultra Classic
Ardeum is offline
post #5 of 13 (permalink) Old 07-16-2012, 10:26 PM
FritzHD's Avatar
And here I've been using a 1 1/2 inch socket on the comp sprocket. Didn't know it had to be super deep, I won't tell my socket, might hurt it's feelings.
Sent from my SAMSUNG-SGH-I897 using Motorcycle.com Free App
FritzHD is online now
post #6 of 13 (permalink) Old 07-17-2012, 05:51 AM
bikedelic's Avatar
I believe Dave is referring to the front final drive sprocket (trans pully).
bikedelic is offline
post #7 of 13 (permalink) Old 07-17-2012, 06:31 AM
FritzHD's Avatar
You're probably right. Final drive socket is a super deep one.
post #8 of 13 (permalink) Old 07-17-2012, 06:55 AM
We need to coin that phrase: Super deep socket.
2005 E.G. Classic
S&S 510 cams
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #9 of 13 (permalink) Old 07-17-2012, 07:14 AM
evohogfarts
ltrhdevo's Avatar
Images: 42
As long as your in there , do the seal on the motor, and depending on the miles also a new stater
knuckle buster
LiveToRideHarleyDavidsonEvo
ltrhdevo is offline
post #10 of 13 (permalink) Old 07-17-2012, 08:05 AM Thread Starter
just about to hit 58,000 on her, so do the stator as well you think?
