Go Back   Harley Davidson Forums: Harley Davidson Motorcycle Forum > Specific Model Areas > VRSC General Discussions
Old 06-05-2008, 09:05 PM   #1 (permalink)
Un-Herd # -1
Nathang's Avatar
Images: 150
After left side dump & frame replacement, is engine moved?
I've got this question posted "over there." ... and a PM to Max but haven't gotten an answer or advice yet. The question is becoming urgent, I've gone 62 days w/o my V-Rod fix...
My left subframe section was bent inwards by my slip & fall, one of the things attached to it was an engine cross-brace, right side of engine anchored by this cross brace to left side of frame. The brace is adjustable, however, while I was able to easily disconnect it from the bent frame section, it will not reconnect to the new straight frame section. There is a good 1/4" to 5/16" gap that seems to indicate that the engine is moved right in the frame by the fall.
No part of the engine was scuffed of bent, nothing seems to have touched the ground, my broken foot provided the padding necessary. That said, it appears that the only thing that could have transferred force to the engine to shift it to the right would have been this same brace/mount assy that now confounds me. I am not willing to just adjust to fit, I am concerned that I need to know what is out of square. Can engine mounts break and act like this? Bike is an '05 B-Rod with under 20,000 miles
Old 06-05-2008, 09:56 PM   #2 (permalink)
DiamondLil's Avatar
Images: 123
Nathan,
One suggestion about your post over there, bring it out of Rhyno's thread and into its own.
http://www.moviephotoforums.com/phot...IMG_0886-2.jpg
2008 VRSCAW V-Rod Custom 0005/1200
“Wit has truth in it; wisecracking is simply calisthenics with words.” Dorothy Parker
12-07-2006
DiamondLil is offline   Reply With Quote
Old 06-05-2008, 11:40 PM   #3 (permalink)
Un-Herd # -1
Nathang's Avatar
Images: 150
Up front now.
Old 06-06-2008, 09:12 AM   #4 (permalink)
COB
GAZOO!'s Avatar
Images: 86
I'd hate to think the motor shifted because that would sound like the frame got tweaked.
Search and ye shall find......the anwer to your exhaust question is in the exhaust forum.....whodda thunk it?
GAZOO! is offline   Reply With Quote
Old 06-06-2008, 04:18 PM   #5 (permalink)
Official Ass Tweaker
Pete Logan's Avatar
What he said - loosen up all the mounts, then see how it fits. If the strap then fits, just tighten up the rest of the motor mounts.
These things are not manufactured perfectly correct - they do have a certain amount of slop built in to them to allow for that.
You are certainly right that if the adjustable strap won't fit, something is wrong.
Maybe loosening up everything will let it all get back into place.
Check with your local dealer whether they can check the frame for straight. Better still, check out how to do that. It's not that tough, all they do is measure between fixed points on the frame.
Personally, given the nature of your down, I seriously doubt you have bent the frame. More likely just knocked something adjustable out a little.
Hol' My Beer, Bubba, An' Watch 'Is
1980 FLH80 Shrine (originally).
Generally speaking, you don't die on motorcycles.
You die a few yards away from what's left of them.
Yes, I have had two bottles of wine. What the fukk is your problem
Pete Logan is offline   Reply With Quote
Old 06-06-2008, 09:24 PM   #6 (permalink)
Un-Herd # -1
Nathang's Avatar
Images: 150
Got good advice... read the f'ing manual...
Do you have the '05 VRSC Service Manual? You shouldn't be attempting this repair without it. The wheel alignment needs to be checked and the engine needs to be centered before installing the stabilizer link. Section 2.28 on pages 2-77 to 2-79 has info on wheel alignment and the engine stabilizer link adjustment.
The manual says..
The stabilizer link between the engine and frame is a horizontal engine locator only. The stabilizer link is not to be used to adjust the horizontal alignment of the rear wheel.
..and also
IMPORTANT NOTE If installing the stabilizer link causes interference between the rear tire and the fender mounting hardware...
Apparently the structural and functional realtionships of these parts are not a simple as they look.
That makes it sound like the pivot points for the swingarm are not integral with the frame, but with the engine/transmission sub-assembly, which would be a floating assembly, relative to the frame. But there are pivot bearing holders integral with the frame.
So if the engine/transmission sub-assembly is not square in the frame, the rear wheel alignment, actually the centering in the fender will be affected?
I think I'm gonna have a headache.
Old 06-07-2008, 05:21 PM   #7 (permalink)
Pete Logan's Avatar
I think I'm gonna join you
Old 06-09-2008, 07:09 AM   #8 (permalink)
70's Drag racer
Dragonfire's Avatar
Images: 13
Your impact causes alot of problems. Engine alignment is important and even the mounts on the off side may be damaged. Buy the service manuel. Best $60 you'll ever spend.
Dragonfire is offline   Reply With Quote
Old 06-09-2008, 01:25 PM   #9 (permalink)
Un-Herd # -1
Nathang's Avatar
Images: 150
I have the manual for both of my bikes.
That's how come I'm quoting it.
Old 06-10-2008, 04:31 AM   #10 (permalink)
Pete Logan's Avatar
My headache came back
vB code is On
