Super Charged 2006 VRSCSE2 clutch - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 1Likes
  • 1 Post By Peter C
post #1 of 3 (permalink) Old 01-06-2017, 09:38 PM Thread Starter
Peter C's Avatar
Hi , don't post very often so excuse me if I get a few things wrong.
After 10 years ( had bike since new) of very hard clutch leaver pressure I'm buying a Slipper clutch
To fit , the blurb says 30% less pressure required , has anybody fitted one and
can make constructive comment please .
On another issue I recently fitted Arnolt air suspension and can recommend fitting it.
Peter C is offline
post #2 of 3 (permalink) Old 01-08-2017, 07:00 PM
Noel
TaxmanHog's Avatar
Images: 5
How much power is the Super Charger giving you??
I used to have a 2004 VRSCA which had a 1320 kit, it was putting out about 145HP
Eventually I upgraded to a slipper clutch, it does require slightly less lever effort
The engagement points are different than the stock setup, but you get used to it.
Can't help with the Air Ride question.
2005 FXDL Dyna Low.
2006 VRXSE Destroyer: VRD-941, SG-941
Best time: 9.661
Best Mph: 139.34 mph
Best 60': 1.393
TaxmanHog is online now
post #3 of 3 (permalink) Old 01-11-2017, 01:46 AM Thread Starter
Peter C's Avatar
Hi taxman, after installation it was dyno'd at 151bhp , it was hard on drive belts , I've since dropped off the tension and had a slight drop in bhp , however, it's now more reliable.
TaxmanHog likes this.
Peter C is offline
