Changing tire diameters? - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Go Back   Harley Davidson Forums: Harley Davidson Motorcycle Forum > Technical > Wheels and Tires
Old 11-05-2012, 09:12 PM   #1 (permalink)
In the wind
TurnCoat's Avatar
Has or does anyone change wheel diameter on their bikes?
It can change a personality of a bike. From going from fat bobber tires to a slimmer front for a sportier looked or a more chopped look?
I have an idea to change a front wheel diameter maybe, possibly...
I find I can go from 16" f & r and then change to a 18" or 19" front and keep the same diameter. Keeping the bike height balance the same front to rear, but making the front tire look taller (bigger rim) and having a lower profile tire to pull it off.
Here is RB Racing's tire diameter calculator. Fun to mess with and find ways to change up your bike. Maybe speed up or slow down the steering on your bike?
RB Racing Tire Diameter Calculator
Anyone doing this?
TurnCoat is offline   Reply With Quote
Old 11-11-2012, 11:19 AM   #2 (permalink)
In the wind
TurnCoat's Avatar
Ok I guess I am the only one thinking of this.
Its good to be original.
Old 11-11-2012, 01:12 PM   #3 (permalink)
THE ROAD's Avatar
Images: 11
WIDE GLIDE came with a 80/21" front stock factory tire & I have changed to a 90/90 21 front tire which is a bit taller & wider which fills in the fender gap nicely and looks & handles a LOT better .
Now , my question is , how much is my speedometer off by ?
THE ROAD is online now   Reply With Quote
Old 11-11-2012, 01:36 PM   #4 (permalink)
The world needs guts
Labradaddy's Avatar
Images: 22
Unless you have an old cable drive speedo ran off the front tire then your speedo shouldn't have been effected Road.
Read tire diameter will change speedo but can be compensated in several ways.
First they came for the Doberman Pinschers and I did not speak out because I did not have a Doberman.
Then they came for the German Shepherds and I did not speak out because I did not have a German Shepherd.
Then they came for the Rottweilers and I did not speak out because I did not have a Rottweiler.
Then they came for mine and there was no one left to speak out for me.
Is your breed next?
Stop BSL now!
Labradaddy is offline   Reply With Quote
Old 11-11-2012, 05:08 PM   #5 (permalink)
THE ROAD's Avatar
Images: 11
Smile
Its an 02 so it doesn't use a cable but why would it not make a difference in the correct speed when useing a taller tire ?
Thanks
Old 11-11-2012, 05:16 PM   #6 (permalink)
Labradaddy's Avatar
Images: 22
The front tire has nothing to do with reading speed.
I believe your 02 reads speed from the output shaft on the trans. Therefore rear tire diameter will have an effect on accurate speedo reading.
Perhaps someone with more knowledge of an 02 can verify.
Is your breed next?
Stop BSL now!
Old 11-11-2012, 05:29 PM   #7 (permalink)
Greasy Member
Speedo drive is off the trans since mid 1990s. Perhaps only the springer softail still maintained the hub drive and a cable drive speedo. All else is electronic. Front tire size will not effect the speedo readings.
Changing the rim size to a larger diameter but maintaining the stock tire height gives the illusion of bigger tire. It uses a smaller size wall which can take away from ride cushioning but reduce sidewall flex and improve cornering and handling.
It can be expensive. Most rims aren't OEM and until recently, you only had the choice 16, 19 or 21 inches. Tire sizes were limited too and until Harley started to use 17s it wasn't until now more options opened up as 17s are popular with the sport bike crowds.
18s make a great substitute for 16s on touring bikes. I had the chance to get 18 inch spoked wheels for my classics and regretfully passed as the price was $500 for the pair......used...with rotors. Some days.... I love this economy.
Football Season is over....
Praise the Lowered!
11 year A.M.A. member.
4 year PA ABATE member.
Old 11-11-2012, 10:13 PM   #8 (permalink)
In the wind
TurnCoat's Avatar
Thanks for understanding the concept Dave. I may end up with a 19" wheel (rim) as it (I hope) could be available as a stock replacement through H-D.
Can stock replacement rims be purchased through H-D?
120/70-19 looks to be the size as the diameter is very close, on a bigger rim, and still look like a fat tire.
But I have to ask myself... should I go for it?
Old 11-12-2012, 01:02 PM   #9 (permalink)
I have a 99 Wide Glide, how much larger can I go on the rear tire before any modifications? Can I go the 140 -16 instead of the standard 130?
billjazzy is offline   Reply With Quote
Old 11-12-2012, 01:36 PM   #10 (permalink)
Greasy Member
Yes. You can go to a 140, but it depends on who makes it as the belt will scrape it. Make sure you have no hardware on the inside of the fender rails that stick out as well. I had a 140mm Dunlop on my 1995 Dyna.
In 2004, HD went to narrower belts, and the 140 came stock on Touring models except for the Deluxe. On 2004-2007, you can fit a 150mm if you ditch the lower belt guard or trim it at a minimum.
Praise the Lowered!
