Thanks Schmidys.... don't the Russell lines have screw in banjo or an3 fittings? I don't think this is the case with this current setup (not to question your judgement but I am confused!).
Attached are some clearer photo's, I am getting quite frustrated as the bike is off the road and I am trying to ID this brand of manifold so I can replace the lower cables to the calipers and the mid line. I can't find the correct type of chrome braided hose and fittings that will be plug and play. Check out the photo #1 and 2.
I ordered the magnumshielding lower assy but it rises behind the triple tree and gets pushed against the frame in front of the tank. I don't trust this set up as it may weaken the braised connection where the mid line hose (to BCU) attaches to the manifold under the triple tree (solid tubing). See picture #3.
I have tried to research further but with no luck - Surely someone may have this set up and can offer some additional advice! I am going nuts...
