Wide Glide rear tire size - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 4 (permalink) Old 11-21-2012, 09:00 AM Thread Starter
I have a 99 wide glide, need a new tire on back. Can I go from the standard size of 130-16 to a 140-16 rear? I have the Michelin Commander on the front, would like to keep that brand!
billjazzy is offline
post #2 of 4 (permalink) Old 11-21-2012, 12:48 PM
Depending on brand width, yes. You may have to take the lower belt gaurd off and trim it a little to make room so it doesn't scrape the tire side wall. In 2004 they went to a narrower belt and a 150 can fit, but barely.
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #3 of 4 (permalink) Old 11-22-2012, 07:36 PM
98DARKHORSE's Avatar
it does come down to brand for sure...even though it may say 140 or 150 or whatever it may be....they dont always measure true....i have a 150 tire on my 98 wideglide and it measures closer to like 145 if i remember right
i only have like 1 mm or so between sidewall and belt...and i do have more room between the guard and the tire then the belt and the tire
98 Evo 83.5ci, custom cam, 44cv, lightened ballanced crank, H-Beam rods, beehive springs, tapered pushrods, johnson hylift lifters, SE slip-ons no baffle, 101.78 hp @ 6200rpm
98DARKHORSE is online now
post #4 of 4 (permalink) Old 11-22-2012, 07:51 PM
Addicted Since 2010
XL1200R's Avatar
Images: 38
The commander is a thinner tire then the stock one, it has less flare on the sidewall. So if a 150 dunlop barely fits a commander will likely fit with a somewhat considerable amount of room to spare
"Mr. Lahey is this you talking or the liquor?"
"Randy...(takes a swig)...I am the Liquor!!!"
XL1200R is offline
