Originally Posted by Rohan
So let's say you run over something on one of your trips and a chunk of the tire (inner tread or sidewall) comes off but the tube inside stays intact... You can at least still get the bike down the road to a service shop and get it replaced.
Now let's say that you have a tubeless tire and the same thing happens... Your tire goes flat and you are stranded or it blows out completely and you have an accident...
-Rohan
If it only worked that way, Rohan.
Tubeless tires will go flat. If it's a nail, it can be removed, plugged as a temporary fix, and filled and ridden home.
When a tube tire fails, even riding on it a short distance, the tire can and usually does spin on the rim, and it tears the stem out almost immediately.
Personally, I have no beefs with tube tires. I probably put about 100K on tube tires. Changing them takes special care and pre-inflating them and then setting the tube before final inflation needs to be done, to make sure the tube isn't twisted or pinched.
These days, face it...... If you get a flat on the road, there's few cases where you're gonna NOT have to be trailered. Finding a nail in a low tire is one thing. Once a tubeless tire pops off the bead on the rim, you're not going to seat that without a compressor.....
Trailer time.
If it's a rear tire on a bagger.......
Trailer time.
If it's a 21" tire on a Softail or XL..... You almost need a machine and especially with a tube.
Trailer time.
Accident....
Ambulance time......followed by trailer time.
