1993 FLSTC Clutch Basket - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 6Likes
  • 2 Post By Alan S
  • 2 Post By SCHMIDTY
  • 1 Post By Alan S
  • 1 Post By ARBY
post #1 of 7 (permalink) Old 04-20-2019, 06:38 PM Thread Starter
Hey Guys, I've got a '93 Heritage that I bought new. Somewhere around 36 thousand miles. I noticed a bit of oil around the primary drain a few years ago, now it's an all out flood. It's coming from behind the inner.The outer isn't cracked around the drain. So, I'm trying to get behind the inner primary to see what all is leaking and I suspect everything, since no one has been back there for 26 years. Or, at least that's what I'm preparing for- replace the seals and bearings- everything. Anyway, Everything is off i.e. compensator bolt(loose, ready to pull); Hayden tensioner; clutch adjuster; snap ring; 'the backwards clutch bolt', all I can see. Should that clutch basket be loose and ready to pull? Because, it's not.... Didn't know if protocol called for light tapping with a pecker(hammer) or a gear puller or did I forget something. I didn't want to bend a sprocket and damage teeth so I haven't done anything but grunt and cuss a lot. I have a service manual and did everything it said to and I'm running out of ideas. The basket is still intact at this point. I didn't want to get in to it if it wasn't necessary. Tried to think of everything to pass along- Looking for tips on this project. Muchly appreciatoed-
Pics upon request
JakeFigg is offline
post #2 of 7 (permalink) Old 04-20-2019, 06:44 PM
Proud Infidel
Alan S's Avatar
The basket can stay together. Sometimes you have to have some kind of prybar on both sides of the basket to ease it out. Just be careful on the inner primary when doing it. Don't mess up the gasket surface.
Sent from my 2 Tin Cans With A String using Tapatalk
gtrman66 and JakeFigg like this.
What is freedom of expression? Without the freedom to offend, it ceases to exist.
Salman Rushdie
Alan S is online now
post #3 of 7 (permalink) Old 04-21-2019, 06:18 AM
SCHMIDTY's Avatar
Like Alan S said. 2 pry bars 180 apart from each other with rags or cardboard to protect the inner primary. Then using your 3rd hand gently rap on the clutch housing with a soft dead blow hammer. The clutch is on the mainshaft splines and is probably bound up a bit is all.
The leak is most likely from the inner primary seal, common problem. I suggest replacing the bearing along with the new seal.
SCHMIDTY is offline
post #4 of 7 (permalink) Old 04-21-2019, 06:27 AM
Proud Infidel
Alan S's Avatar
I'm glad I wasn't taking a sip of coffee when I read that portion.
SCHMIDTY likes this.
Salman Rushdie
post #5 of 7 (permalink) Old 04-21-2019, 07:30 AM Thread Starter
....good thing you didn't say 3rd leg. I'd have been SOL... Thanks for the tip!
JakeFigg is offline
post #6 of 7 (permalink) Old 06-21-2019, 08:13 AM
Comfortably Numb
ARBY's Avatar
Images: 10
All your inner primary seals need to be replaced and you might as well replace the two tranny seals and the big "O" ring up front while you have things apart.
I had the same problem on my 93 Heritage and just pulled it all apart and changed them all a couple of weeks ago.
Kainam likes this.
"There must have been a door there in the wall when I came in!"
ARBY is online now
post #7 of 7 (permalink) Old 06-21-2019, 06:52 PM
Dan89flstc's Avatar
Deleted...
1989 FLSTC
2016 FLHR
Dan89flstc is online now
Similar Threads
2015 street bob transmission/primary problems. Clutch basket stuck Tealblackfxdb Dyna General Discussions 33 07-11-2018 06:43 PM
2001 Road King Clutch Basket/Starter Ring Sprocket Seperation BC.Buchanan Touring General Discussions 5 04-02-2017 07:13 PM
95 clutch basket Badbet1 Trans/Primary 16 02-11-2016 06:44 AM
1993 FLSTC Headlight question. ARBY Softail General Discussions 2 12-29-2015 09:07 AM
EVO clutch basket El Diablo Classified - Wanted 14 03-05-2014 07:11 AM
