Engine guard & fwd controls - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 17 (permalink) Old 10-11-2011, 07:09 AM Thread Starter
Rockhanger's Avatar
Is There a combination of an engine guard and forward controls that will work on a 2003 Lowrider? Anyone got this setup?
Rockhanger is offline
post #2 of 17 (permalink) Old 10-11-2011, 07:16 AM
I, personally, have never seen it aftermarket, but that doesn't mean it doesn't exist.
The only OEM set up I'm aware of was on the FXDP Police bikes. With the FXDP, it's almost $800 for the parts from HD, and about $400 used if you can find them, not including the engine guard.
Anyone creative enough could make something work, then sent it for rechrome after modding it, but it depends on what you wanna spend.
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #3 of 17 (permalink) Old 10-11-2011, 09:20 AM
SCHMIDTY's Avatar
A combination engine guard with built in forward controls ??? I don't remember ever seeing anything like that before . One problem with that setup that I can imagine is that engine guards always seem to get bent when the bike falls over .
There are guards with built in retractable foot pegs tho .
SCHMIDTY is online now
post #4 of 17 (permalink) Old 10-11-2011, 06:08 PM
Addicted Since 2010
XL1200R's Avatar
Images: 38
Ain't that the magic sentence
"Mr. Lahey is this you talking or the liquor?"
"Randy...(takes a swig)...I am the Liquor!!!"
XL1200R is offline
post #5 of 17 (permalink) Old 10-12-2011, 12:00 PM
Wide=Glide and Rider
geouhl's Avatar
Maybe I'm missing something but how does the mount for the low rider differ than a mount for a wide glide? They have crash bars (sorry, engine guards) where the bottom mounts to the same spot as where the forward controls are. Possibly not the same but here is a WG from a while ago. Not the greatest picture but you get the idea.
Sometimes I feel like an idiot. But I am an idiot, so it kinda works out!
geouhl is offline
post #6 of 17 (permalink) Old 10-12-2011, 12:20 PM
The wideglide is raked farther, and has OEM forward controls with rear the master cylinder up front and floor boards.
The FXD models do not. FXD's have their rear master at the rear of the bike, with a short rod going to it. Lendthen the rod for forward controls, and it's prone to flexing, and the rear brake feels soft.
As well....the only forward control set-up made OEM was for the police bikes with running boards, and the mounts sat back a tad farther, then any aftermarket set does.
That slight forward stance is enough to interfere with the front wheel.
2005 E.G. Classic
S&S 510 cams
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #7 of 17 (permalink) Old 10-12-2011, 12:34 PM
geouhl's Avatar
The rear master cylinder on my WG is at the rear of the bike with the rod you mention going to it. It's not up by the brake pedal.
geouhl is offline
post #8 of 17 (permalink) Old 10-12-2011, 12:44 PM
The genuine H-D engine bars on my 2008 FXDL do not mount where the forward controls go. They have U-bolts that go round the frame tubes just in front of the regulator. This means that the H-D forward controls fit as per the Accesories book. I don't know how this differs fromthe 2003 model.
And Dave is correct as always - that rod has a compound bend which makes it too flexy!
Baldrick is offline
post #9 of 17 (permalink) Old 10-13-2011, 08:25 PM Thread Starter
Rockhanger's Avatar
Sorry, I mis stated question. I just installed forward controls on my 2003 Lowrider and wanted to know if their is an engine guard that will bolt on in addition to fwd. controls. Will one for a Wideglide work on a Lowrider? Has anyone got this setup?
Thanks for any help.
post #10 of 17 (permalink) Old 10-14-2011, 09:03 AM
I've done the same on my 2008 Low Rider. The catalogue says the engine bars fit 06-on Dynas - don't know what the difference is with a 2003. They bolt round the frame leaving the lugs free for the forward controls.
You can see the bend in the brake rod that causes the flexing!
btw, the controls are mounted on Accutronix Kick-Back plates 'cos I've got short legs!
Baldrick is offline
Similar Threads
Bassani Prostreet Heat Shields FWD Controls Dyna sirbOOm Classified - Wanted 0 07-21-2011 06:47 PM
Sportster fwd controls daffydog Sportster General Discussions 5 05-06-2011 03:03 AM
fwd controls for dyna sg (09) young one Dyna General Discussions 6 01-02-2010 01:59 AM
fwd controls... jimmy22 New to the Community 2 04-01-2009 11:03 PM
