Harley Dyna Streetbob 2014 sputtering P1632 code - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 2 (permalink) Old 08-06-2019, 06:43 PM Thread Starter
Hi guys. Need some help here on some maybe cheap rectification before I get to Harley dealership which is quite far from the place I live. Only code it is giving is P1632 odometer learned up. I checked the obvious battery connections and looked for any loose wires but didn't find anything.
Speed sensors dirty or faulty? Ignition switch issue?
Anything that I can check easily without loosing pennies by sending to dealership as I need to tow the bike to avoid break down in middle of road.
Issue:
After a 2000km ride to different country, on the way back I have issues with the bike showing sign of loss of power. Thank god no issue while reaching destination And I manage to reach home safely. My speedo dropped to 0 but only for a moment and the bike started back up and speedo came back.
I knew something was but I manage to ride below 100km hr to reach home safely. Need to pull the clutch and rev to make sure the bike is up to speed.
Rectification attempt done myself:
1. I have New battery cables and Battery changed prior to the ride. Thinking maybe the battery is an issue I took the effort to reclaim a new battery from dealer thinking it was a battery issue. Changed it but issue still persists. Bike jerking and showing sign of stalling upon reving up the throttle and will die during at traffic lights or whenever I pull the clutch.
2. Changed my spark plugs and gave it a good service after the long ride.
After performing all rectification above, my dyna spitting and sputtering still persists . It's like every time it would sputter the bike was actually shutting off because the abs light would come on and the speedo would drop to 0 then catch back up.
Sorry for the long post but any help would be great. Thanks.
harleyfreak89 is offline
post #2 of 2 (permalink) Old Today, 01:22 PM
MFXDB's Avatar
Maybe this helps. There was a recall on ignition switches: https://www.autoblog.com/2014/08/03/...switch-recall/
Used to be a link on the HD site to check your vin so try looking for it.
I know you changed the battery cables but double check them, especially the ground to the starter.
2007 Street Bob
ThunderMax
DK 587
Ohlins
MFXDB is online now
