Help!!! Fuel supply tube and fuel rail spraying out fuel!!! - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 1Likes
  • 1 Post By misinlink
post #1 of 6 (permalink) Old 02-22-2018, 02:01 PM Thread Starter
I have fuel spraying out where the fuel supply tube meets the fuel rail, Ive replaced the o-ring and the washer and its still leaking! Its on an 05 dyna superglide custom. Any help would be greatly appreciated! Thank you.
Luceroryan is offline
post #2 of 6 (permalink) Old 02-22-2018, 02:08 PM
Negative Ghost Rider
Did you actually get the old oring out
ZombieOutlaw likes this.
~ Humphrey Bogart
misinlink is offline
post #3 of 6 (permalink) Old 02-22-2018, 03:07 PM
Asylum Inmate
bbally's Avatar
Second for old oring
Sent from my SAMSUNG-SM-G891A using Tapatalk
Don't be a Puss .. Collision 2019, "Closer to east coast. Make plans now, attend must be the priority! "
USMC Sgt 79-85
Malo periculosam, libertatem quam quietam servitutem
Western Colorado PGR
2003 VRSCA
2016 FLTRXS
AMA PAC Supporter
bbally is online now
post #4 of 6 (permalink) Old 02-22-2018, 03:38 PM Thread Starter
I was told grease might help...?
post #5 of 6 (permalink) Old 02-27-2018, 01:23 PM
MFXDB's Avatar
Grease won't stop a fuel leak. It might help to install a new o-ring. If you did get the old one out, take a look at the new one to make sure it wasn't damaged when put in.
2007 Street Bob
ThunderMax
DK 587
Ohlins
MFXDB is online now
post #6 of 6 (permalink) Old 02-27-2018, 06:28 PM
Keep on Ridin
Silverback's Avatar
Images: 14
Make sure the new o-ring is correct. Generic o-rings dont always match the correct cross-section thickness. On that critical seal, I would only use the genuine OE seal and have the parts guy double check the application.
"There's no sensation to compare with this
Suspended animation, a state of bliss
" --Pink Floyd
** This line seems to come to mind often while I'm riding.
"Men do not quit playing because they grow old. They grow old because they quit playing." --Oliver Wendell Holmes
"And miles to go before I sleep
...and miles to go before I sleep." -- Robert Frost
If you give up drinking, you don't live longer...it just seems longer
Silverback is offline
