Fuel pump - Page 3 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 9Likes
post #21 of 59 (permalink) Old 04-17-2019, 11:53 AM
South GA Redneck
baggerboy's Avatar
If you sent power to the pump, it shouldve ran. Only other reason would be bad pump, (which you said was new) or the system is already primed. (ie like when you first switch the bike on and the pump cycles and cuts off before you start up)
baggerboy is online now
post #22 of 59 (permalink) Old 04-17-2019, 12:35 PM
norm9278's Avatar
Ok, wait a minute. Back in post #4 you said you could hear the fuel pump....now you can't?
The fuel pump runs when you first turn on the ignition switch (knob), has nothing to do with the start button. It will run for about 3 seconds to pressurize the system, then shut off until the engine starts or you cycle the ignition switch again. If this is not happening you need to check for power at the fuel pump connector.
Sent from my coal fired bag phone using Tapatalk
norm9278 is online now
post #23 of 59 (permalink) Old 04-17-2019, 01:35 PM Thread Starter
Sorry norm9278, I work on my bike, but never got this deep into it, I am rushing instead of taking my time, ur right must check power to fuel pump connector. I hear the tech going thru it's cycle thks, trying to get on road, trip in may
Tiolou21 is offline
post #24 of 59 (permalink) Old 04-17-2019, 01:49 PM
South GA Redneck
baggerboy's Avatar
Take a deep breath and walk away for a little bit. Sometimes when I do that and come back, things just fall into place. And dont get in a rush, usually never works out. Youll get it
post #25 of 59 (permalink) Old 04-17-2019, 02:00 PM
Is the Fuel check valve directional? could it be in the wrong way?
SuperDave071 is offline
post #26 of 59 (permalink) Old 04-17-2019, 02:10 PM
norm9278's Avatar
Can't be done. Even by a screw up like me!
SuperDave071 likes this.
post #27 of 59 (permalink) Old 04-17-2019, 02:49 PM
Barney Fife - Poser
<G Man>'s Avatar
Did you reconnect power to the injectors?
The whole line needs to be pressurized for the injectors to spray. It sounds like maybe your quick-connect is not engaging properly at the check valve (keeping the valve closed)... or maybe the check valve has gone bad (or got clogged).
***oops, didn't read to the end before replying***
G Man
Quotes found on the internet are not always accurate. - Abraham Lincoln
Silence is golden , duct tape is silver.
Stay back 200 feet - not responsible for damaged feelings.
<G Man> is online now
post #28 of 59 (permalink) Old 04-17-2019, 04:36 PM
norm9278's Avatar
Is the tach on the fuel tank? What you should hear from the pump is a buzz or really fast ticking sound for 3 seconds as soon as you turn the key.
I don't know why a tach would make sounds?
post #29 of 59 (permalink) Old 04-17-2019, 09:49 PM Thread Starter
Thks guys, I have to find which fuel pump connector is bad in side fuel,pump or out side, so tomorrow drain tank, follow out side fuel connector line see were current starts and end, don't know how to trace three prong connecter tho, hopeful can find a way
Tiolou21 is offline
post #30 of 59 (permalink) Old 04-17-2019, 09:52 PM Thread Starter
Plus norm the check valve goes one way, how u were when u were in ur twentys straight lol
Tiolou21 is offline
Similar Threads
Help!!! Fuel supply tube and fuel rail spraying out fuel!!! Luceroryan Fuel Systems 5 02-27-2018 06:28 PM
2001 Fuel Injection Fuel Pump?? flhtcCarl Fuel Systems 12 12-03-2010 08:47 AM
02 FLSTFI Fuel Pump pw16k10 Fuel Systems 0 03-19-2009 03:52 PM
fuel pump issue Hornet745 Electrical 4 10-25-2008 02:34 PM
Road king fuel pump line leaks(holes) docroz Touring General Discussions 3 05-15-2007 07:31 PM
