Fuel pump - Page 5 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 9Likes
post #41 of 59 (permalink) Old 04-23-2019, 11:25 AM Thread Starter
Fuel pump not getting current
Used light tester to test all fuse ports, all gave power except fuel pump fuse spot?
Tiolou21 is offline
post #42 of 59 (permalink) Old 04-23-2019, 11:50 AM
FritzHD's Avatar
Was your run/stop switch set to run? Change fuse?
FritzHD is online now
post #43 of 59 (permalink) Old 04-23-2019, 12:21 PM
SCHMIDTY's Avatar
FYI, the fuel pump circuit is only active for 3 seconds then shuts down after the engine starts !
SCHMIDTY is offline
post #44 of 59 (permalink) Old 04-23-2019, 03:32 PM Thread Starter
Yes, tried with power on and off
Tiolou21 is offline
post #45 of 59 (permalink) Old 04-23-2019, 03:37 PM Thread Starter
Plus tested fuse ok, and I was told about the 3 sec rule from, norm9278, or baggerboy
Tiolou21 is offline
post #46 of 59 (permalink) Old 04-23-2019, 03:40 PM Thread Starter
The fuel pump, fuse port has no power
Tiolou21 is offline
post #47 of 59 (permalink) Old 04-23-2019, 03:59 PM
norm9278's Avatar
Ok, no power to either side of the fuse AT KEY ON, correct?
If so, try switching the relays around. They are the two small boxes plugged into the fuse panel, both are the same, just switch them.
Also, run a hot wire from the battery + to the fuel pump fuse. Does the pump run when you do that?
Sent from my coal fired bag phone using Tapatalk
baggerboy likes this.
norm9278 is online now
post #48 of 59 (permalink) Old 04-25-2019, 03:11 PM Thread Starter
Ok norm switch nothing,wire from battery to fuse port neg, and poz side nothing, used two wires nothing, couple days ago when using tester fule pump fuse port did show current one time and one time only
Tiolou21 is offline
post #49 of 59 (permalink) Old 04-25-2019, 03:36 PM Thread Starter
Scratch every thing first time trying to diagnose, put neg tester wire on neg side battery, put tester in fuel pump fuse port, got a light norm9278
Tiolou21 is offline
post #50 of 59 (permalink) Old 04-25-2019, 03:37 PM
South GA Redneck
baggerboy's Avatar
Sounds like you may need to check the chassis grounds. If you didnt get voltage u til you went straight to battery for ground
baggerboy is online now
Similar Threads
Help!!! Fuel supply tube and fuel rail spraying out fuel!!! Luceroryan Fuel Systems 5 02-27-2018 06:28 PM
2001 Fuel Injection Fuel Pump?? flhtcCarl Fuel Systems 12 12-03-2010 08:47 AM
02 FLSTFI Fuel Pump pw16k10 Fuel Systems 0 03-19-2009 03:52 PM
fuel pump issue Hornet745 Electrical 4 10-25-2008 02:34 PM
Road king fuel pump line leaks(holes) docroz Touring General Discussions 3 05-15-2007 07:31 PM
