Fuel Sending Unit Help - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 2Likes
  • 2 Post By Rknob
post #1 of 5 (permalink) Old 08-20-2019, 11:17 AM Thread Starter
I am new to the forum and would appreciate any advice.
I just replaced my fuel check valve assembly on my 2013 Fat Boy Lo. It all went well (or so I thought) with no leaks and it run fine, but now my LED fuel gage reads low, one light only, even with 4 gallons of gas in the tank. When I turn on the ignition, the fuel gage lights up with all lights on and then drops to the one light.
I did I miss something like having to reset the LED fuel gauge or possibly not connected the gauge correctly? I would truly love to avoid removing everything again to see if somehow the check valve assembly hose is blocking the sending unit. Any advice or suggestion would be appreciated.
Rknob is offline
post #2 of 5 (permalink) Old 08-20-2019, 11:43 AM
South GA Redneck
baggerboy's Avatar
I would check to see if the sending unit got damaged when changing the check valve. Also make sure the electrical connections are good.
baggerboy is offline
post #3 of 5 (permalink) Old 08-22-2019, 07:29 AM Thread Starter
Thank you, I'm going to check both today but I hope it is a loose connection.
Rknob is offline
post #4 of 5 (permalink) Old 08-23-2019, 11:55 AM Thread Starter
The problem was a loose connection in the tank. All is good now, thanks again.
Kainam and baggerboy like this.
Rknob is offline
post #5 of 5 (permalink) Old 08-23-2019, 12:17 PM
South GA Redneck
baggerboy's Avatar
Thanks letting us know how it turned out!
