Carb off, fuel. Carb on, No fuel - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 5Likes
post #1 of 11 (permalink) Old 08-27-2019, 12:09 PM Thread Starter
Ironcliffs's Avatar
So I have 97 Fxdwg. It was sitting for 9 months. Accelerator pump nozzle wasnt spraying spraying fuel into carb. Get carb all clean. Soak jets and lower bowl in vinger and lemon juice. Check it off the bike sprays fuel perfectly. Put it on the bike and after a couple throttle twists I get no fuel out of the nozzle.
Drain my gas tank because I've had these paint chips coming loose from a previous owners lining of the tank. (Attached pic). After draining there was definitely dirt and sediment in the bottom of the bucket. (Attach pic of fuel filter). Brand new fuel line from petcock to carb inlet.
Ironcliffs is offline
post #2 of 11 (permalink) Old 08-27-2019, 12:40 PM
candyman1340's Avatar
Don't eat the paint chips!.......they'll give you gas.
Take the tank off and clean out the inside as best you can. Rinse out the tank.
Put some nuts and bolts inside the tank (count them.... so you'll know how many to remove when you are done) and shake the tank to loosen the pealing paint inside the tank.......several old pillows and a clothes dryer will speed up the process and give you time to do more important things.
Central joe likes this.
candyman1340 is online now
post #3 of 11 (permalink) Old 09-03-2019, 08:45 AM
Call me Gig.
Wrgiacona's Avatar
Worth repeating.
____________________________________
6/14/14 2014 FLHXS Street Glide Special Black Denim
6/30/11 2011 FXDC Super Glide Custom Vivid Black
The days I now describe as the dark time.
1979 to 1981 Yamaha 200
1976 to 1979 Suzuki 185
Wrgiacona is offline
post #4 of 11 (permalink) Old 09-03-2019, 04:41 PM Thread Starter
Ironcliffs's Avatar
Had tank cleaned at a local shop. Bought a new fuel valve kit with filter and all. James carb rebuild kit, new fuel hoses. When carb is off bike, fuel comes thru accelerator pump nozzle. When I put it on the bike, no fuel going to the carb. Fuel is on. Gas in tank. No fuel. Im at a total loss
post #5 of 11 (permalink) Old 09-04-2019, 10:40 AM
South GA Redneck
baggerboy's Avatar
Petcock is vacuum operated. If you put carb on bike with no gas in the bowl, it wont fill up until you crank the bike. Cranking the bike will create the vacuum needed to allow the gas to flow into the bowl.
Smoketown$1 and 1/2 Ton like this.
baggerboy is offline
post #6 of 11 (permalink) Old 09-04-2019, 04:19 PM
DLM Prez's Avatar
Okay, it might be this, cuz I was going to say you might have a southern hemisphere carb that operates the opposite way a northern hemisphere carb does.
God made everyone right-handed, the truly gifted overcome it.
DLM Prez is online now
post #7 of 11 (permalink) Old 09-04-2019, 05:57 PM Thread Starter
Ironcliffs's Avatar
I thought even with it not running I should be able to pull gas directly from the fuel valve with a vacuum pump? 😔
post #8 of 11 (permalink) Old 09-04-2019, 06:34 PM
Senior Flatulant
Smoketown$1's Avatar
Remove the fuel hose from the carb and put it in a container.
Turn on the petcock.
Does fuel run out of the hose?
No?
Attach vacuum line to the vacuum port on the petcock and attach a low volume vacuum pump. ('Oral' works too. Just pinch the hose with Vise-grips so you don't lose the vacuum.)
Fuel run now?
No?
Take petcock apart as you may have a bad diaphragm. Some replacements are/were available from the dealer. Otherwise, it may be new petcock time.
If you're cheap, cut half of the pin length off of the diaphragm and put it back together. Just remember to turn off the fuel when you park the bike.
Good aftermarket ones cost about what a replacement one costs. They also require you to turn off the fuel when you park the bike but, they're almost bullet-proof.
A replacement stock one will cost about the same as the one above but, in theory, if the bike is not running the fuel will not drain into the motor.
Cheers,
Smoketown
1/2 Ton likes this.
2003 FXST & 2013 CVO Ultra
Smoketown$1 is online now
post #9 of 11 (permalink) Old 09-04-2019, 11:01 PM Thread Starter
Ironcliffs's Avatar
No?
Fuel run now?
No?
Cheers,
Smoketown
I have a brand spankin new petcock (stock) on there. Ive done all those things trying to get a drop of fuel to come out to no avail.
My local HD tech thought something might be screwy with the gas cap. Its a vented cap.
post #10 of 11 (permalink) Old 09-04-2019, 11:36 PM
Loosen the cap.
If the tank has a vent tube , make sure it is not blocked.
Smoketown$1 likes this.
