Ignition Relocation ?????????? - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 17Likes
  • 2 Post By sardonicus87
  • 2 Post By MFXDB
  • 5 Post By Thunder~Struck
  • 5 Post By Alan S
  • 3 Post By Cyureus
post #1 of 6 (permalink) Old 09-05-2019, 12:43 PM Thread Starter
Just asking because I see a lot of it....why relocate the ignition??
fishnpickles is offline
post #2 of 6 (permalink) Old 09-05-2019, 02:08 PM
weird member
sardonicus87's Avatar
Location: Dothan, AL (I "aint from 'round here" though)
On what, exactly? There's different kinds of aftermarket ignitions, different ingitions through the years, models, etc. Also, what specifically about the ignition? The ignition is a whole system. On my 97 softail, the stock ignition system runs from the timing cup in the cone, across the bottom of the right side frame to the ignition module under the seat, over to the ignition coil on the left. There's others that the coil is located where my horn is, some the coil is just in front of the front cylinder. Depends on wherever you got room to stick it. And even then, for some the ignition key switch (if that's what you're talking about) is different on different bikes. Some, like Sportsters or some aftermaket tanks, don't have a dash, so it's on the frame somewhere. My sister's 2003 883, if I remember right, is on the right side toward the front somewhere. Mine is on my tank dash and uses a barrel key, hers uses a normal (?) type key.
Are you asking about relocating the ignition (what part though, the core of all systems is in the timing cone on the right side of the engine case)? Or do you mean the starter switch? The coil? Key switch?
Even then, some do it for aesthetic reasons I guess? Some it's for a modified or different coil that won't go where the stock one did.
slingshot383 and fishnpickles like this.
Kyle
1997 Softail Custom (FXSTC) [the red one]
1997 Softail Custom (FXSTC) [RIP 6 Nov, 2018]
You've got to play the hand that you're dealt, and sometimes life deals you a losing hand, well then you're a loser, and you have to deal with it.
sardonicus87 is online now
post #3 of 6 (permalink) Old 09-05-2019, 02:42 PM
MFXDB's Avatar
A common one is on the bikes where the ignition switch is on the steering head. It's kind of a pain in the ass and the key can (and usually will) fall out when it gets turned off.
slingshot383 and sardonicus87 like this.
2007 Street Bob
ThunderMax
DK 587
Ohlins
MFXDB is offline
post #4 of 6 (permalink) Old 09-05-2019, 05:30 PM
Wayward Son
Thunder~Struck's Avatar
Why not??
Why relocate the coil??
Why change the pipes??
Why customize and personalize at all??
Because be are all different and because we can.
You`ve been
Thunder⚡️Struck
ATW
1L/TWF
🇺🇸 R.E.D.
People are why I love Dogs and my Harley.
💔In Loving Memory💔
❣️Thor❣️
09-08-17
🐾No longer by my side. Forever in my heart.🐾
🖤Bear, Brute, Jessie James, Billy the Kid, Aiyana🖤
ROLO
04-03-14 > 07-27-16
Ed
11-20-17
Bee
No such thing as just a Dog.
Thunder~Struck is offline
post #5 of 6 (permalink) Old 09-05-2019, 06:29 PM
Proud Infidel
Alan S's Avatar
Originally Posted by Thunder~Struck View Post
:... and because we can.
The #1 reason for doing anything. Even things that aren't logical.
Sent from here to there.
What is freedom of expression? Without the freedom to offend, it ceases to exist.
Salman Rushdie
Alan S is online now
post #6 of 6 (permalink) Old 09-09-2019, 09:11 AM
Cyureus's Avatar
I know on the iron, one reason to relocate the coil was to help with airflow across the heads. I relocated my coil to the bottom of the jugs, above the primary, and the ignition switch to behind the rear just under the seat. Looked good to me.
Sent from my SM-N950U using Tapatalk
2011 Suzuki Boulevard S40 - LS650 (Traded)
2013 Iron 883 - XL883N (Traded)
2018 Sport Glide - FLSB
Cyureus is offline
