new starter clutch assy/ drains battery - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 6Likes
  • 2 Post By Ddaddyo
  • 1 Post By Pred8er
  • 2 Post By norm9278
  • 1 Post By SCHMIDTY
post #1 of 9 (permalink) Old 09-10-2019, 04:57 PM Thread Starter
I have a 2007 ultra which was making a strange grinding noise when I started it after it was running a while. I put a new starter clutch assembly into the starter and put everything back together. The bike started fine , so I went for a 10 mile ride to warm it up. Got home , turned it off and tried to restart it to see if it would make that strange grinding noise. The bike would not start due to the drain on the battery. It sounded like it wanted to start but just not enough volts. Put it on the tender over night and it started right up the next day. Went for a 60 mile ride and when I got home turned it off and tried to restart it. Battery was absolutely dead, only a clicking. Put it on the tender over night and the battery is recharged. Any thoughts on what could be draining the battery while it is running?
Torch is offline
post #2 of 9 (permalink) Old 09-10-2019, 05:01 PM
Old Skool
Ddaddyo's Avatar
Charge the Battery and have it Load Tested. If the Battery is good, check running Voltage. Make sure all Connections are Clean & Tight.
SoftailBilly and sardonicus87 like this.
I may be Old but I Refuse to Grow Up.
Ddaddyo is online now
post #3 of 9 (permalink) Old 09-10-2019, 05:04 PM
Try'n to behave
Pred8er's Avatar
Test your voltage regulator. You may be running off your battery instead of off the charging system.
sardonicus87 likes this.
That look on my face is not concern, its shock at your utter stupidity!
They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety-Benjamin Franklin 1759
Running is not a plan, running is what you do when your plan fails.
Pred8er is online now
post #4 of 9 (permalink) Old 09-10-2019, 05:55 PM
norm9278's Avatar
On the starter stud are both wires connected? You didn't forget to hook up the smaller wire?
Sent from my coal fired bag phone using Tapatalk
sardonicus87 and 1/2 Ton like this.
norm9278 is online now
post #5 of 9 (permalink) Old 09-11-2019, 06:55 AM
SCHMIDTY's Avatar
Agreed, sounds like the charging system is at fault.
SCHMIDTY is offline
post #6 of 9 (permalink) Old 09-11-2019, 01:14 PM
Super Moderator
ematicic's Avatar
Images: 9
Starter could be going too. Fresh teeth on that clutch, everything tight in there. I agree, it does sound like the charging system but something to consider.
"Men can only be highly civilized while other men, inevitably less civilized, are there to guard them" - George Orwell
ematicic is online now
post #7 of 9 (permalink) Old 09-11-2019, 05:03 PM
SoftailBilly's Avatar
Charging system is bad should have thrown a code ? All great suggestions.
Stay Vertical
USAF Veteran, Patriot Guard Rider.
2009 Softail Custom in Vivid Black, 3"Slip ons, SE A/C Kit, Knight Rider Xieds, SE Compensator, Fork Brace and some more chrome to polish.
SoftailBilly is online now
post #8 of 9 (permalink) Old Yesterday, 07:17 PM Thread Starter
Thanks to everybody for the suggestions.
Torch is offline
post #9 of 9 (permalink) Old Yesterday, 07:18 PM Thread Starter
Thanks everybody for the suggestions
Torch is offline
