Oil check.. Cold vs. Hot - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 18Likes
post #1 of 33 (permalink) Old 06-07-2014, 09:56 AM Thread Starter
Flat Land Redneck
Old Coot's Avatar
Images: 25
The book says check hot. Let it idle a few min. then check. Would the oil not drain into the pan over night? Who checks their oil hot or cold? Cold, my level is at the add line. Haven't checked it hot lately. I don't understand the reasoning for checking hot. Seems best to me to let it drain into the pan over night and check before riding. Any thoughts, opinions or advise?
Old Coot is offline
post #2 of 33 (permalink) Old 06-07-2014, 10:00 AM
Oil expands when hot , that is why.
webco2 is offline
post #3 of 33 (permalink) Old 06-07-2014, 10:52 AM
MVious1's Avatar
Oil quantity is only 3- 3.5 qts or so it wont expand a lot there is a range on the stick so hot /cold whatever if it is hot just let it sit a few minutes after shutting the engine off before checking the level. Keep it in the range listed on your stick. I know the stick says hot but mine is in the mid range hot or cold with little variation. Hot vs cold on mine is a diff of about 1/8" on the stick.
You Lie and I'll swear to it
One Life One Chance
Make it idiot proof and someone will make a better Idiot
MVious1 is offline
post #4 of 33 (permalink) Old 06-07-2014, 11:34 AM
Done
When you change oil, why don't you just remember where the level is on the stick when cold. Then if you check it again cold, you have a reference point.
Yon Yonson is offline
post #5 of 33 (permalink) Old 06-07-2014, 11:48 AM
THE ROAD's Avatar
Images: 29
Thumbs up
+1
I agree with you . Drather check it cold than hot as hell ,drippin hot oil everywhere .
My book says two & a half quarts on a oil & filter change . That puts the oil level dead on the half-way mark between full & add marks . If I happen to check it hot it will be dead on the full mark .
Bike uses no oil between changes and doesn't blow out any oil into the air filter and I regularly redline it with drag pipes & all . LOL .:bikerguy:
THE ROAD is offline
post #6 of 33 (permalink) Old 06-07-2014, 12:50 PM
Kainam's Avatar
Images: 150
Harley motors are dry sump motors. If you check cold you run into the chance of getting false low readings due to oil getting past the check valve and draining into the crank case.
By checking hot, the oil pump scavenges the oil out of the crankcase and pumps it back into the oil tank, which is where you are measuring the level..... not the crankcase as with the majority of automotive engines.
tekslk likes this.
Mala Ipsa Nova
Psalm 144:1 Luke 22:36
'05 Carbed Night Train
111 rwhp, 112 rwtq
Best 1/4 ET 12.557s
Best 1/4 MPH 108.59
http://weathersticker.wunderground.c...ansas_City.gif
Kainam is online now
post #7 of 33 (permalink) Old 06-07-2014, 01:16 PM
tibadoe's Avatar
Images: 10
I check both cold and hot levels. No problem.
Joe
Stage I w/SE A/C & SEST
V&H Dresser Duals w/4" Rineharts
HD Oil Cooler w/Low Temp Thermostat
Flo Oil Filter/Cooler
"Whether you think you can or whether you think you can't, either way you're right!" - HF
tibadoe is offline
post #8 of 33 (permalink) Old 06-07-2014, 01:19 PM
chasarms's Avatar
This. If you add oil cold, you can overfill - especially on a Softail.
Sent from Motorcycle.com App
Ddaddyo likes this.
2011 Ultra Classic Electra Glide FLHTCU
FM 107 10.5:1 | Woods 777 Cams | Jackpot 2/1/2 SPC | Jackpot 4" Dyno Tuned Mufflers | DynoJet PowerVision
chasarms is online now
post #9 of 33 (permalink) Old 06-07-2014, 02:57 PM
Check hot.
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #10 of 33 (permalink) Old 06-07-2014, 04:47 PM
THE ROAD's Avatar
Images: 29
Question
Softies have the oil tank separate from the engine and above the tranny . Dyna's have the oil below the engine in the oil pan .
So , would there be any difference in the correct procedure for checking oil ?
THE ROAD is offline
Similar Threads
1979 SPORTSTER oil tank, hot and cold while running jimlisa Oil and Filters 7 12-23-2016 12:15 PM
Hot Oil Tank. Hot! Hot! exterminater Oil and Filters 16 12-21-2016 08:00 PM
OIL vs OIL vs OIL??????? igya Sportster General Discussions 24 03-15-2014 08:25 PM
Cold idle rpm's vs hot idle rpm's TC88 EFI bbqbrisket Dyna General Discussions 2 10-05-2012 02:05 PM
New from Cold, Cold Canada! Crazy_Train New to the Community 51 02-07-2010 04:45 PM
