Frustrated...2003 Road King...won't start, no spark, no fuel..please help - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 16 (permalink) Old 06-15-2011, 04:07 PM Thread Starter
Angry Frustrated...2003 Road King...won't start, no spark, no fuel..please help
I have a 2003 Road King...got on it yesterday, started it normally after a minute or so it died. Went to start it again and won't start. No spark or fuel, does crank. Crank sensor is new. Should the crank sensor have voltage to fuel pump? Anyone have any ideas...thank you in advance for any help.
gjhotrods is offline
post #2 of 16 (permalink) Old 06-15-2011, 04:10 PM
Have you checked for diagnostic codes? There's a "sticky" in the "electrical" section for this, by year.
Codes will point you in the right direction.
Crank sensor is for ignition and injector pulse. if EFI.
Check fuses too.
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #3 of 16 (permalink) Old 06-15-2011, 04:22 PM Thread Starter
Fuses are good. No codes. Crank sensor ok. Have voltage to fuel pump. Just won't start, no spark and no fuel.
post #4 of 16 (permalink) Old 06-15-2011, 04:23 PM
"Ain't quite right"
Motive's Avatar
Any changes made to the bike since the last time it was running? You mention new crank sensor, I'm assuming it was the same problem before the new one?
'08 VRSCDX aka 'the Rod'
2019 FXDR
"The powers not delegated to the United States by the Constitution, nor prohibited by it to the States, are reserved to the States respectively, or to the people."
"A government big enough to give you everything you want is a government big enough to take from you everything you have."
Originally Posted by chris_lacey View Post
Motive.......honest to God, what is wrong with you?
Originally Posted by XDixiecratX View Post
Well Motive, stay out of Vegas, cause you aint playin with a full deck.
Motive is offline
post #5 of 16 (permalink) Old 06-15-2011, 04:29 PM
When you turn the key, does the fuel pump buzz? If not: Check relays/fuses.
Does it have an alarm system?
Have you checked the battery terminal tightness?
2005 E.G. Classic
S&S 510 cams
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #6 of 16 (permalink) Old 06-15-2011, 05:34 PM Thread Starter
To Motive: I replaced the crank sensor because I had an eratic misfire and slight hesitation. I just recently replaced the gear in my tranny (6 speed).
To Dave63: I get occasional fuel pressure but no spark. There is voltage to the fuel pump. No alarm system in the normal sense just the security system that doesn't let the bike run, seems to be ok though. Checked the terminals they are ok on the battery.
post #7 of 16 (permalink) Old 06-16-2011, 08:22 AM
SCHMIDTY's Avatar
- The fuel pump will only run for 3 seconds untill the engine starts . Check the ignition fuse inside the right side cover , two fuses there , ecm / ignition and fuel pump .
- Engine cranks but doesn't start and no codes setting indicate a problem that's outside of the EMS , engine management system .
- Remove and inspect / clean the speed sensor located on top of the trans at the end of the starter . EMS needs to see a signal from the speed sensor .
- Check that the fuel feed hose is plugged into the tank bung secure , unplug and replug it .
- Engine compression needs to be present to check for spark so checking with the plug out and grounded to the head won't give good results . Install a spark tester in series with the wire and plug .
- The fuel pump feed hose inside the tank could have a hole in it resulting in low fuel pressure .
- Hope some of this info helps ya find the problem .
SCHMIDTY is online now
post #8 of 16 (permalink) Old 08-09-2011, 12:59 PM Thread Starter
Back again......
Been having alot problems with the bike......just replaced the ecm. Ran great over the weekend and yesterday coming into work.....got on it to go home and cranks but won't start. There is no spark. Anyone have any ideas here.....Thanks
post #9 of 16 (permalink) Old 12-14-2015, 08:28 PM
I was reading this blog because I was having the same issue. I removed the quick disconnect at the bottom of the tank. Relieved the pressure in the line going to the pump. Wiped both ends down with a clean rag and it left a little black on the rag. Reconnected the line and she fired right up. Took it for a 30 mile ride and had no problem. Shut it off and restated sever times. Thanks for the post. Same me big $$ 2005 FLHRCI ROADKING
DAVE DAVIS is offline
post #10 of 16 (permalink) Old 12-14-2015, 08:31 PM
Wayward Son
Thunder~Struck's Avatar
Appreciate the info on what worked for you. May help someone down the road.
But, uh, thread is 4 years old.
You`ve been
Thunder⚡️Struck
ATW
1L/TWF
🇺🇸 R.E.D.
People are why I love Dogs and my Harley.
💔In Loving Memory💔
❣️Thor❣️
09-08-17
🐾No longer by my side. Forever in my heart.🐾
🖤Bear, Brute, Jessie James, Billy the Kid, Aiyana🖤
ROLO
04-03-14 > 07-27-16
Ed
11-20-17
Bee
No such thing as just a Dog.
Thunder~Struck is offline
Similar Threads
2002 road king classic will not start, please help big wood Engine 16 04-28-2015 09:44 PM
2003 Road King Running Issues HELP PLEASE hdph1957 Performance 7 09-08-2014 08:12 AM
Won't start.....Please help PhillyPyro Sportster General Discussions 4 05-21-2012 04:00 PM
no fuel- no spark -no headlights Rockarosa New to the Community 49 07-18-2011 02:59 PM
