need help with 2001 Road King - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 1Likes
  • 1 Post By baggerboy
post #1 of 4 (permalink) Old 04-17-2019, 10:06 PM Thread Starter
Need help please 2001 Road King with efi (I know it sucks but the bike was set up awesome, thought it would be an easy fix to change out efi) Bought this last year and its had some problems but runs great. Ran it two months ago while it was stored in my garage which is dry and it started right up and ran great. Went to start it two days ago and it started right up but the throttle will not turn. Can't accelerate the engine. Took the throttle handle housing apart and it looks fine, took the cables off. Grabbed them with pliers and no movement. Took the air cleaner off and everything looks fine. No clue desperately need help. haven't been working due to illness and money is tight so any advice or insight would be great. Haven't been catching any breaks altely.
Rolandroadking is offline
post #2 of 4 (permalink) Old 04-18-2019, 04:53 AM
South GA Redneck
baggerboy's Avatar
Take the cables off at the throttle body and check to see if theyre froze up. If they are, you may be able to free them up with some lube but chances are youll need some new cables. Also check to make sure the throttle body isnt binding in any way.
Breeze3at likes this.
baggerboy is online now
post #3 of 4 (permalink) Old 04-18-2019, 05:37 AM
Breeze3at's Avatar
Sounds silly, but check the throttle cable cams on the throttle body for acorns (or other foreign objects) jammed in there. Lil' critters can do strange things in garages.
I ride like an old guy that wants to get older.
Pete / Breeze .380
Breeze3at is online now
post #4 of 4 (permalink) Old 04-18-2019, 06:03 AM
SCHMIDTY's Avatar
Agreed. Take the throttle handle apart then remove the air cleaner and back plate to gain access to the cables from both ends. Rotate the throttle plate by hand to verify that it's not bound up then try moving the cables from both ends. If you can get the cables to move it would be a good time to dribble some cable lube thru them from the top until the lube runs thru to the bottom.
ALSO verify the throttle friction lock on the bottom of the throttle grip is loosened.
SCHMIDTY is online now
Similar Threads
road king,t road king classic or road glide? Dubee Touring General Discussions 15 09-29-2012 04:54 AM
Help! 2001 Road King Crank Position Sensor 98HDRK Touring General Discussions 3 03-28-2010 07:30 AM
2001 road king trikerhd New to the Community 1 07-11-2009 05:13 PM
2001 Road King won't start Jerseygent Fuel Systems 4 05-20-2009 08:27 AM
2001 Road King hd4evr Touring General Discussions 13 05-12-2009 08:24 AM
