96 Road King crank no start - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 6 (permalink) Old 05-23-2019, 06:58 AM Thread Starter
I have a 1996 HD Road King with fuel injection. Some times it will crank but no start. Other times it starts just fine. During the times it does not start you CAN hear the fuel pump kick on. There is a stored trouble code but when I try cycling the key 3 time the check engine light flashes to fast to count in order to see which code is being tripped. Any suggestions? Leaning towards the Crank Positioning sensor or Temp Sensor.
Oldscutlass1973 is offline
post #2 of 6 (permalink) Old 05-23-2019, 07:27 AM
SCHMIDTY's Avatar
That's not the way to retrieve codes. Try this; Hold the speedo trip button in while turning the ignition on, wait for diagnostics to appear in the odo window, then use the trip button to cycle thru the diagnostics. Note: the procedure and code descriptions are in a sticky in the electrical section.
SCHMIDTY is offline
post #3 of 6 (permalink) Old 05-23-2019, 07:33 AM
Negative Ghost Rider
He has a 96... that should be the old school way cycle the ignition count flashes from cel.
~ Humphrey Bogart
misinlink is offline
post #4 of 6 (permalink) Old 05-23-2019, 08:20 AM
SCHMIDTY's Avatar
[QUOTE=misinlink;7279547]He has a 96... that should be the old school way cycle the ignition count flashes from cel.
The electronic speedo will run codes. OP should try that and if it doesn't work then he needs to follow the procedure in the electrical sticky, NOT quick cycling the ignition switch, that's a no-no on the older M&M EFI bikes.
SCHMIDTY is offline
post #5 of 6 (permalink) Old 05-23-2019, 08:40 AM
FritzHD's Avatar
Check your voltage. Them old evo's will spin but won't start if voltage is low.
FritzHD is online now
post #6 of 6 (permalink) Old 05-24-2019, 06:40 PM
Hit it she goes boom
GotGold's Avatar
Reminds me.. check your battery, make sure its good. My 98 Sporty would spin all day long but not fire, if the battery was going bad. Lead to a lot of "wait for him to start his bike first" comments when on a trip...
"Our lady of blessed acceleration don't fail me now."--- Elwood Blues
"What does not kill you makes you stronger..... except for bears, bears will kill you."
"Give her full throttle till ya see God... then back off"--- Some guy in a bar.
GotGold is offline
Similar Threads
'09 Fat Bob. Starter engaged, didn't disengage, no headlight, no fuel pump, no start. BruinFatBobGuy Electrical 5 04-14-2017 03:56 PM
Frustrated...2003 Road King...won't start, no spark, no fuel..please help gjhotrods General Service and Repair 15 04-28-2016 02:52 PM
Crank But No Start realking Electrical 7 10-29-2009 08:44 PM
09 Road King would crank over but not start Texmark Electrical 13 05-31-2009 12:16 AM
