tinging noise - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 3Likes
  • 1 Post By MFXDB
  • 2 Post By kd5cqt
post #1 of 7 (permalink) Old 09-18-2019, 08:41 AM Thread Starter
tinging noise
I have a 2014 FLHTK with 14,000K on it. Last year I started noticing a tinging type noise, not sure where it is coming from. The best way I can describe it is sounds like when you shut the bike off, the sound the exhaust makes when it is cooling only much louder. When I first heard it I had thought maybe it was rocks hitting the fender but it is not. It does it when it is hot outside and the bike is hot and I notice it mostly around 2500 to 3000 rpm of when riding two up or if I get on it a little bit. It does not happen when the bike is in neutral even if revved to higher RPM's and seems to be around 2nd and third gear. I posted to a local forum and had a few people tell me it sounds like the compensator. I took it to Harley and they told me they could not hear the noise but my gear shifter was loose and all they could hear is the rattle form that. they fixed that but it is still doing it. It is beginning to get louder. any suggestions would be helpful.
tscherer is offline
post #2 of 7 (permalink) Old 09-18-2019, 02:16 PM
MFXDB's Avatar
Doubt it's the compensator. Sounds more like preignition that happens with a hot motor and when you put it under load. Is the bike stock or do you have some kind of tuner or other mods that have been done? More info, please.
marshmallow likes this.
2007 Street Bob
ThunderMax
DK 587
Ohlins
MFXDB is offline
post #3 of 7 (permalink) Old 09-18-2019, 02:30 PM
Mississippi Cajun
kd5cqt's Avatar
Just tad curious here, but is it possible you accidentally filled the tank with regular gas?
SoftailBilly and JLR like this.
USAF Veteran, PGR Member, Retired Old Fart! 2015 Electraglide Ultra Limited
Hey, immigrants: Learning English and assimilation to American culture is NOT a suggestion!
kd5cqt is online now
post #4 of 7 (permalink) Old 09-18-2019, 05:36 PM
^^^^^^ refill tank with known good HI-test, add a little gas treatment.
bobf is online now
post #5 of 7 (permalink) Old 09-18-2019, 07:42 PM Thread Starter
No, stock except for slip ons, only run sunoco, 93 octane, also this has been going on since last year, have filled many times and I don’t believe i have ever put in anything else but sunoco since i purchased. I had thought about preignition however it does not quite like that but similar, but then again i am used to hearing preignition in cars.
tscherer is offline
post #6 of 7 (permalink) Old 09-19-2019, 01:18 PM
knocking in an air cooled engine is a lot louder than in water cooled engines.(no water jackets to damp the sound)
bobf is online now
post #7 of 7 (permalink) Old 09-19-2019, 08:04 PM
SoftailBilly's Avatar
Pull the plugs check for color light brownish, might be running lean.
Stay Vertical
USAF Veteran, Patriot Guard Rider.
2009 Softail Custom in Vivid Black, 3"Slip ons, SE A/C Kit, Knight Rider Xieds, SE Compensator, Fork Brace and some more chrome to polish.
SoftailBilly is online now
